Cascadnig question - Urgent
I have followed exactly the same rules/ syntax but it's not working as
required - see attached my XMLForm. Any help is highly appreciated.
Irum
Irum Jamshed | Manager - Data Management
International Rescue Committee
mailto:Irum.Jamshed@pakistan.the Irum.Jamshed@pakistan.theirc.org | +92
91 5703310 (Ext-105) | rescue.org
Irum-code.xlsx (58 KB)
Irum,
If you want to use KoBoForm to build in your Cascading Selections, you may
find it a lot easier. KoBoForms are fully compatible with ODK Collect, so
you can inter-operate freely. We do a lot with cascading selections, so
it's been a feature we put some work into.
There is an instructional video that will tell you how to do it (Bottom of
page, Tutorial #5) : KoBoForm Video
Tutorialshttp://www.kobotoolbox.org/node/102
If you need more details, you can get them in the user guide:
http://www.kobotoolbox.org/support/userguide/koboform/cascadingselect
☞§※☼:airplane::open_umbrella::slight_smile:
~Neil
··· On Tue, Feb 26, 2013 at 5:48 AM, Irum Jamshed < irum.jamshed@pakistan.theirc.org> wrote:
I have followed exactly the same rules/ syntax but it’s not working as
required – see attached my XMLForm. Any help is highly appreciated.****
Thanks****
Irum****
irc.org
| +92 91 5703310 (Ext-105) | rescue.org
"ODK Developers" group.
Dear Neil,
I agree but the only problem I am facing is that my location list is more than 5000 and I have to out PCodes. Which means manually entering them in the KOBO.
Irum
··· From: opendatakit-developers@googlegroups.com [mailto:opendatakit-developers@googlegroups.com] On Behalf Of Neil Hendrick Sent: Tuesday, February 26, 2013 8:40 PM To: opendatakit-developers@googlegroups.com Subject: Re: [ODK Developers] Cascadnig question - Urgent
Irum,
If you want to use KoBoForm to build in your Cascading Selections, you may find it a lot easier. KoBoForms are fully compatible with ODK Collect, so you can inter-operate freely. We do a lot with cascading selections, so it's been a feature we put some work into.
There is an instructional video that will tell you how to do it (Bottom of page, Tutorial #5) : KoBoForm Video Tutorials http://www.kobotoolbox.org/node/102
If you need more details, you can get them in the user guide: http://www.kobotoolbox.org/support/userguide/koboform/cascadingselect
~Neil
On Tue, Feb 26, 2013 at 5:48 AM, Irum Jamshed irum.jamshed@pakistan.theirc.org wrote:
I have followed exactly the same rules/ syntax but it’s not working as required – see attached my XMLForm. Any help is highly appreciated.
Irum
mailto:Irum.Jamshed@pakistan.the Irum.Jamshed@pakistan.theirc.org | +92 91 5703310 (Ext-105) | rescue.org
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com mailto:opendatakit-developers%2Bunsubscribe@googlegroups.com .
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
Irum,
You can just import the whole set as a CSV.
Just set up your CSV with the administrative area titles across the top.
One row for each final level selection.
Region,Sub-Region,Country
Africa,Eastern Africa,Burundi
Africa,Eastern Africa,Comoros
Africa,Eastern Africa,Djibouti
Africa,Eastern Africa,Eritrea
Africa,Eastern Africa,Ethiopia
Africa,Eastern Africa,Kenya
Africa,Eastern Africa,Madagascar
Then, use the Add Data Import CSV function.
[image: Inline image 1]
Copy and paste in your CSV. Give it a name, click import.
KoBoForm will auto generate a set of questions for you using this data set.
~Neil
··· On Tue, Feb 26, 2013 at 8:20 AM, Irum Jamshed < irum.jamshed@pakistan.theirc.org> wrote:
Dear Neil,****
the KOBO.****
Irum****
Irum,****
it's been a feature we put some work into. ****
page, Tutorial #5) : KoBoForm Video Tutorialshttp://www.kobotoolbox.org/node/102
☞§※☼:airplane::open_umbrella::slight_smile:****
~Neil****
irum.jamshed@pakistan.theirc.org> wrote:****
Thanks****
Irum****
irc.org
