In Central when creating a public access link, regardless of if I select the "Single Submission" checkbox, the generated URL always has /single/
in it and the survey redirects at the end to the "Thank you for participating! You can close this window now." screen.
versions:
e16b79530756bbd825f68275b3b6e53951409474
70ec99f02885a06e37709db6319bfdf96fac84eb client (v1.2.2)
59556ecea91f0a25678cd6da0084adb7e66ca099 server (v1.2.1)
Hi @danbjoseph! It's expected that the URL will always have /single
in it: what's different between the URLs is the ID after /single
. I think it's expected that both will redirect to the thank you page afterwards. However, if Single Submission is Yes, then the user won't be able to use the same device to visit the link again and submit. (The docs have a more detailed explanation of how that works.)
Ah, got it that makes sense, and a read through of the docs definitely makes it clear.
