I'm trying to change Collect's (v1.1.7) URL to my copy of Aggregate,
so I can upload my form, but in Collect's main menu I don't have a
"Menu" button (or any other option that will take me to server
preferences). The only options I have in the main menu are: start new
form, continue saved form, send finished forms, and manage forms. How
do I get to server preferences??
From the ODK Collect Main Menu, press the physical Menu Key on your
phone and tap Preferences.
BRYAN
On Jul 13, 3:46 pm, Anika wrote:
> Hi,
> Thanks for your help!
> Anika
Oops, dumb question. Thanks for the quick response!
> BRYAN
> > Hi,
> > Anika
What URL did you use to access the local server version?
Chris Buddenhagen
Oops, dumb question. Thanks fo> Oops, dumb question. Thanks for the quick
response!
>> BRYAN
>> > Hi,
>> > Anika
if you are going from the emulator, localhost is at 10.0.2.2. if you
are going from a device, then it's your localhost's external ip.
> Chris Buddenhagen
>> response!
>>> BRYAN
>>> > Hi,
>>> > Anika
