I have a survey that is in Spanish so when the enumerator tries to
skip a question, the pop up messages shows "Sorry, this response is
required." Is it possible to make this response in Spanish?
it may be easier to use a regex for the constraint, and then customize
the constraint message in the form to whatever language you want. this
should work file in all versions of collect. collect 1.1.7 release
will also support multi-lingual constraint messages.
yaw
On Fri, Oct 7, 2011 at 09:16, Sanjeev Swamy wrote:
> Hi Guys,
> Also,
> does ODK allow line breaks? like in HTML.
> Thanks,
> Sanjeev
Did you ever find out if ODK allows line breaks? I am designing my form in
excel
On Friday, October 7, 2011 6:16:12 PM UTC+2, Sanjeev Swamy wrote:
> Hi Guys,
> Also,
> Thanks,
> Sanjeev
On Oct 7, 6:46 pm, Yaw Anokwa wrote:
> sanjeev,
> the text for the required response (just like the button text and the
> menu text) is in the collect code, so that localization will have to
> take place in /res/values.http://developer.android.com/guide/topics/resources/localization.html
> yaw
> > Hi Guys,
> > Also,
> > Thanks,
> > Sanjeev
In excel you can add line breaks using alt+enter (it may be ctrl+enter in
other spreadsheet software). In the xform line breaks are just line breaks
in the text itself.
Regards,
-Nathan
On Thursday, August 30, 2012 11:52:27 PM UTC-7, Imobi wrote:
> Hi,
> excel
> Thanks
>> Hi Guys,
>> Also,
>> Thanks,
>> Sanjeev
