I want to keep the media URL links active from the Blobstore of an old
form but clean out most of the old records of the form on the AppEngine
instance of Aggregate. Using Briefcase, this is possible. I can download
all the old data, wipe the form, clean up the data with the relevant info I
wish to keep, and then use Briefcase to upload the photo files with
associated UUID's. This way I can keep the URL's associated with the
correct photos and the correct records in Sheets, CSVs, Fusion Tables, or
whatever.
All of this worked but then I wanted to rename the uploaded form so if the
original was "TestForm1" I could upload it and the media data as say,
"TestForm2014". I can't make this work at all, even a minor change from
something like "TestForm1" to "TestForm2" results in the following error
(using three test entries as an example):
Preparing for upload of form definition with 0 media attachments
Uploading form definition with no media attachments
retrieving next chunk of instanceIds from server...
Preparing for upload of submission (1 of 3) with 1 media attachments
Uploading submission (1 of 3) and 1 media attachments
UPLOAD FAILED: Submission upload failed. Detailed error: Internal Server
Error (500) while accessing: https://example.appspot.com/submission
Please verify that the URL, your user credentials and your permissions are
all correct.
Preparing for upload of submission (2 of 3) with 1 media attachments
Uploading submission (2 of 3) and 1 media attachments
all correct.
Preparing for upload of submission (3 of 3) with 1 media attachments
Uploading submission (3 of 3) and 1 media attachments
all correct.
Partially successful upload...
Keep in mind that as long as I keep the "Testform1" name this works without
a problem. As best as I can tell, the UUIDs of the original records
preserve the original name of the form (e.g. Testform1) as well.
So is it possible to change the name of the form somehow? Or is there a
better way to keep archived photos with easy to use links in the cloud?
Using another method I can download all this info locally along with the
photos and, with great annoyance, make local URLs but we're moving
completely to a Google environment soon and changing /media/photoname.jpg
will be really difficult to do other than one by one. One form alone has
92 photos attached.
Thank you for your assistance!
whatever.
all correct.
all correct.
all correct.
without a problem. As best as I can tell, the UUIDs of the original
records preserve the original name of the form (e.g. Testform1) as well.
92 photos attached.
-within the form xml:
-<h:title>Example Form 1</h:title> becomes <h:title>Example Form
2</h:title>
becomes
-all references to the original ID get changed,
e.g. nodeset="/exampleform1/Photo" changes to
nodeset="/exampleform2/Photo"
-the above were changed regex Find/Replace in Notepad++
-deleted the info.db directory
-I changed each submission.xml file so that the beginning of the file that
reads: <exampleform1 id="ExampleForm1" becomes <exampleform2
id="ExampleForm2"
-Probably not important but I used grepWin to change these files en
masse.
Then I uploaded the using the Push function in Briefcase. Even if I
uploaded to a different ODKAggregate instance (I have production and a test
instances of it) I get the same errors.
By the sound of your response this should be possible so I've very curious
to find out what I might have messed up along the way.
Thank you!
On Friday, March 18, 2016 at 3:32:50 PM UTC-6, Mitch Sundt wrote:
> It is unclear how you are modifying the ODK Briefcase Storage content to
> achieve this.
> Within the form directory,
> - update the form xml to have the new form id.
> - delete the info.db directory.
> - within each instances/.../submission.xml file, change the id=""
> attribute to specify the new form ID.
> On Fri, Mar 18, 2016 at 1:32 PM, Greg <greg....@edmonton.ca > wrote:
>> Hi,
>> old form but clean out most of the old records of the form on the AppEngine
>> whatever.
>> the original was "TestForm1" I could upload it and the media data as say,
>> are all correct.
>> are all correct.
>> are all correct.
>> 92 photos attached.
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
What you did is what I think should work. The changing of the top-level
element name is not necessary within ODK Aggregate (other servers pay
attention to that name). So you could have left that as ODK
Aggregate uses the id attribute to match a submission with its form
definition. That avoids a lot of changes in the rest of the form definition
document (just a one-liner).
Make sure that the revised form validates with ODK Validate. Then try to
upload that form definition onto ODK Aggregate by itself. That would at
least verify that the form definition changes you did were all OK.
On Mon, Mar 21, 2016 at 8:28 AM, Greg wrote:
That's pretty much what I did. More specifically:
2</h:title>
becomes
id="ExampleForm2"
masse.
Thank you!
achieve this.
whatever.
Server Error (500) while accessing: https://example.appspot.com/submission
are all correct.
are all correct.
are all correct.
92 photos attached.
Groups "ODK Community" group.
Mr. Sundt, you are a genius! It worked!! This part "So you could have
left that as " is the key. You have to leave that one alone
but the Title and ID can be changed. That will work for me though. The
Title and ID are all I need to change to keep them names of archive
materials separate from current in use forms and maintain the URL links
for data already collected. I'm hoping that made sense! This is great
news!
Thank you very, very much!
>> -Example Form 1 becomes Example Form
>> 2
>> becomes
>> that reads: <exampleform1 id="ExampleForm1" becomes > id="ExampleForm2"
>> masse.
>> curious to find out what I might have messed up along the way.
>> Thank you!
>>> achieve this.
>>> On Fri, Mar 18, 2016 at 1:32 PM, Greg wrote:
>>>> Hi,
>>>> whatever.
>>>> are all correct.
>>>> are all correct.
>>>> are all correct.
>>>> a better way to keep archived photos with easy to use links in the cloud?
>>>> the photos and, with great annoyance, make local URLs but we're moving
>>>> 92 photos attached.
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
