Changing odk Collect to point to ODKAggregate n emulator
Hi!
How can I point ODK Collect to download forms from my ODKAggregate in my
appspot account in the eclipse.
regards
Arindam
The secret of health for both mind and body is not to mourn for the past,
worry about the future, or anticipate troubles, but to live in the present
moment wisely and earnestly.....
Gautam Buddha
This is more appropriate for opendatakit-developers@
Please use that list for software development questions.
Replying on that list.
··· On Wed, Aug 22, 2012 at 1:31 PM, Arindam Bhattacharjee < arindam.rbt@gmail.com> wrote:
Hi!
regards
Arindam
Gautam Buddha
Are you running ODK Collect within Eclipse? If so, just configure it with
the appspot hostname.
Or are you running ODK Aggregate in Eclipse and want to have ODK Collect to
reach it?
If the later, you need your security.server.hostname to be the IP address
of your computer
(not 127.0.0.1 or localhost).
Rebuild and verify that you can log into your ODK Aggregate instance via
your browser.
Then verify that you can reach the ODK Aggregate webpage via the phone's
browser.
You may need to adjust your computer firewall or work with your network
administrator to do so.
See:
http://opendatakit.org/use/aggregate/tomcat-install/#Configure_for_Network_Access
Once you can access the ODK Aggregate webpages from the browser, you would
then
configure ODK Collect with the server URL, etc. for that.
Note that ODK Collect 1.2 settings should not have anything configured for
"Google Account"
There's a bug related to this setting that will be fixed in the next
release.
Hi!
regards
Arindam
Gautam Buddha
I am in this case. I tried to look for hostname in the present file. It
points to http://opendatakit.appspot.com, in string.xml which is part of
many folders. Do you want me to change it in every folder viz
values,values-ca....
or I can change in one configuration file and the output will be reflected
in all these files..I cannot find this declaration.
to reach it?
of your computer
your browser.
browser.
See:
then
"Google Account"
release.
Hi!
regards
Arindam
Gautam Buddha
Gautam Buddha
You should be familiar with the app on a phone before working in Eclipse.
See the documentation here: http://opendatakit.org/
i.e., from the menu button, there is a change settings page.
And work through android SDK example apps from the Android site.
··· On Wed, Aug 22, 2012 at 2:09 PM, Arindam Bhattacharjee < arindam.rbt@gmail.com> wrote:
with the appspot hostname.
to reach it?
of your computer
your browser.
browser.
See:
would then
for "Google Account"
release.
Hi!
regards
Arindam
past, worry about the future, or anticipate troubles, but to live in the
present moment wisely and earnestly.....
Gautam Buddha
Gautam Buddha
Mtch
The thing is, I can do it in the android phone. I dont see the option of
changing the url in android emulator(I dont understand how to call the
change setting function), that's why I asked if it could be done in some
settings file.
Is this the problem with AVD of the emulator. I am able to run these apps
on emulator, only thing is(the option of change settings does not show up)
. As of now this was downloading forms from opendatakit.appspot.com.
Also on odkaggregate, even if I login with gmailid. I am not able to
download forms in odk collect with the gmail password. I was able to
download by adding a new user.
Arindam
reflected in all these files..I cannot find this declaration.
to reach it?
address of your computer
your browser.
browser.
See:
would then
release.
Hi!
my appspot account in the eclipse.
regards
Arindam
Gautam Buddha
Gautam Buddha
Gautam Buddha
You're probably running a 4.0 Android phone emulation. The menu button is
going away, so the newer emulator phone skins have a very very tiny sliver
icon to activate the menu. Read up on this UI change on the android site.
It is still accessible, but just not easy to find. ODK Collect runs on
2.2.3 and later. Run an earlier emulator skin, and you will have a more
obvious menu button.
The Google Account in ODK Collect is not used for authentication; only
username/password are. Google Account can be specified so that it will be
saved into a form with a preload property (not yet documented). However,
there is currently a bug in ODK Collect that screws up authentication if
this is set, so do not set a Google Account (if you do, you will need to
clear app data to clear it out -- there is no way to remove the account
once added). This will be fixed in the next ODK Collect release.
··· On Fri, Aug 24, 2012 at 11:47 AM, Arindam Bhattacharjee < arindam.rbt@gmail.com> wrote:
Mtch
settings file.
Arindam
of many folders. Do you want me to change it in every folder viz
Collect to reach it?
via your browser.
phone's browser.
See:
would then
release.
Hi!
regards
Arindam
Gautam Buddha
Gautam Buddha
Gautam Buddha
Thanks Mitch
I spent so much time trying to figure this out.
Mtch
settings file.
Arindam
It points to http://opendatakit.appspot.com, in string.xml which is
part of many folders. Do you want me to change it in every folder viz
via your browser.
phone's browser.
network administrator to do so.
See:
would then
release.
Hi!
regards
Arindam
Gautam Buddha
Gautam Buddha
Gautam Buddha
Gautam Buddha
Sorry, the ODK Collect is crashing in Android 3.2. In Android 2.3.3, I get
the following error: (Re-installation failed due to different application
signatures.)
Cant I instead change the server-path locally
Can I change
https://opendatakit.appspot.com
to point to my account and generate a new build file.
I have to remove this in a lot of files locally though....
and remove the googleid from appspot.
regards
Arindam
··· On Fri, Aug 24, 2012 at 3:11 PM, Arindam Bhattacharjee < arindam.rbt@gmail.com> wrote:
Thanks Mitch
Mtch
settings file.
apps on emulator, only thing is(the option of change settings does not show
up) . As of now this was downloading forms from opendatakit.appspot.com.
Arindam
Eclipse.
via your browser.
phone's browser.
See:
would then
configured for "Google Account"
release.
Hi!
in my appspot account in the eclipse.
regards
Arindam
Gautam Buddha
Gautam Buddha
Gautam Buddha
Gautam Buddha
Gautam Buddha
This is a separate issue.
Uninstall ODK Collect from your emulator (or phone), then use Eclipse to
run or debug your version on the emulator. This error is because you have
installed a Google Play version of ODK Collect, and Eclipse will not allow
you to overwrite this with its development copy.
··· On Fri, Aug 24, 2012 at 1:30 PM, Arindam Bhattacharjee < arindam.rbt@gmail.com> wrote:
signatures.)
Can I change
regards
Arindam
Thanks Mitch
is going away, so the newer emulator phone skins have a very very tiny
sliver icon to activate the menu. Read up on this UI change on the android
site. It is still accessible, but just not easy to find. ODK Collect runs
on 2.2.3 and later. Run an earlier emulator skin, and you will have a more
Mtch
of changing the url in android emulator(I dont understand how to call the
settings file.
Arindam
Eclipse.
it with the appspot hostname.
via your browser.
phone's browser.
See:
would then
release.
Hi!
regards
Arindam
Gautam Buddha
Gautam Buddha
Gautam Buddha
Gautam Buddha
Gautam Buddha
