Char limits with strings in Collect
Hi folks,
I just realized the old 255 character limit appears to have been removed at
some point in Collect. It used to be that a user had to override it with
`odk:length="600" in the bind. Previous discussions
https://groups.google.com/d/topic/opendatakit/2lcMAMnGoTE/discussion showed
that there was a reason for limiting it to 255 in the first place, but I
couldn't find any reference in release notes or issues why this limit was
lifted or if it was set to a new (arbitrary) number. As far as I understand
XML 1.0 doesn't set any limits, but I'm not sure if that's the case with
Collect at the moment.
Tino
Hi Tino,
The length isn't there for Collect. It's a hint to Aggregate to
allocate more space for the database table. See Datastore String
Length section at https://opendatakit.org/help/form-design/guidelines
for more.
What behavior are you seeing?
On Tue, Aug 25, 2015 at 10:08 AM, Tino Kreutzer tino.kreutzer@kobotoolbox.org wrote:
Hi folks,
`odk:length="600" in the bind. Previous discussions showed that there was a
reason for limiting it to 255 in the first place, but I couldn't find any
reference in release notes or issues why this limit was lifted or if it was
set to a new (arbitrary) number. As far as I understand XML 1.0 doesn't set
any limits, but I'm not sure if that's the case with Collect at the moment.
Tino
"ODK Developers" group.
Hi Yaw,
My bad, I thought this was a limitation within Collect in the past but I
see now that this only ever applied to Aggregate.
Tino
··· On Tue, Aug 25, 2015 at 11:04 AM Yaw Anokwa wrote:
Hi Tino,
for more.
Hi folks,
at
was a
was
set
moment.
Tino
