Hi fam,
I have a long list of multi choice which i expect one to pick majority of the provided choices with the exception of 1-2 answers depending on a criteria they earlier selected. I would like the long multi-choice list to be all-checked by default so that one would only uncheck 1 or 2 choices which are not applicable to them to easen the process. Is this possible? how would I go about configuring the default feature?
This is only appropriate if you want exactly the calculated value to be submitted. Please make sure to make the field read-only in that case.
If you do want a user-modifiable value, it should be in the default column OR in a calculation wrapped in once depending on the context. Please share your form or a small sample of the same structure if you need help with this.
