I am asking users their choice about multiple Brands, using combo box. If
user select option A in Choice 1, then in Choice 2 and Choice he should not
be allowed to select option A. But he can choose "None" as option in Choice
1, Choice 2, Choice 3.
You can add a constraint to Choice 2 that complains if it is the same
option as for Choice 1 and asks the user to pick a different option.
Similarly, for Choice 3, a constraint can be constructed if the option
picked for 3 was already picked for 1 OR 2.
I have done this the challenge I am facing is "None" it is a valid option
for some of the choices so I want to take None as valid option for multiple
answers
>> Choice 1
>> Choice 2
>> Choice 3
>> Attaching form
>> "ODK Developers" group.
>> email to opendatakit-developers+unsubscribe@googlegroups.com
>> For more options, visit https://groups.google.com/groups/opt_out.
You should just be able to wrap the and that excludes duplicates with an or
that allows 'None' i.e., do something like:
constraint="(string(/data/Top_of_Mind_Brands/TMB_Rank6) = 'None') or (...)"
where ... is the and clause that excluded the duplicate selections.
On Fri, Feb 22, 2013 at 10:09 PM, techbyte wrote:
Thanks For Reply.
option for some of the choices so I want to take None as valid option for
multiple answers
If user select option A in Choice 1, then in Choice 2 and Choice he should
not be allowed to select option A. But he can choose "None" as option in
Choice 1, Choice 2, Choice 3.
Choice 1
Choice 2
Choice 3
Attaching form
an email to opendatakit-developers+**unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
