Dear ODK Implementers,
I need to identify the most reasonable hardware to implement a survey
in Nigeria (with about a hundred surveyors). So, I'd be interested to
hear what phones you chose and any advice you may have? (I've only
played with the HTC MyTouch and the Nexus One, but looking at the ODK
FAQ I'm leaning towards the HTC Magic)
Did you buy extra batteries? If so, what'd you get? Any thoughts on
hand cranks?
Thanks for the advice, Andrew
The Magic/MyTouch is a good field unit. It has decent battery life and it's
solid, you can drop it without breaking it.
G1s don't have good battery life, so I would steer clear of those.
As for batteries, you can buy extra batteries, but that won't stop you from
having to recharge. You have to focus off your recharging. In the fields, we
don't have extra batteries, but we have a lot of stuff for recharging. We
have Solios for when we are far out in the field and don't have access to
electricity. You can get through several days, but you can't run your whole
operation on solar power, the solar batteries take 10 hours in the sun to
charge.
We travel in groups, and we drive, so a good solution has been Car chargers.
We just get a converter so that in the truck I can have a regular outlet. I
plug in a USB hub and I can recharge a whole team's gear on the drive home.
For your home base, you need a whole assortment of step down converters (to
clean your AC power), power strips, USB hubs, and charge cables. Don't try
to get gear to match the local electric power grid, get gear to convert the
power so that the gear you can buy in the US will work locally. I can give
you more details on specific hardware if you are interested.
100 is a lot of surveyors, what is your sample size? To justify buying 100
Androids, I am assuming it's huge. Our last survey had a sample size of 2800
and we had 32 surveyors taking 4 surveys each per day. Every day of data
collection pulled 128 records. We finished in under a month.
Neil
hand cranks?
☞§※⌘:airplane:
~Neil
Andrew,
Not sure this falls under traditional hardware but you may want to consider
some sort of cases for your phones. We are currently using "dry paks",
which are cheap-ish (~10-20 USD) and water proof. They are difficult to use
at first but after the membrane gets a worn in it becomes just fine to use
in all conditions.
Here are a few photos to illustrate what they look like.
(1)http://picasaweb.google.com/lh/photo/h9mXXsb6oMNi-KDiZkynvdOn8JZBJKeOhX6kAQVvb9s?feat=directlink
and
(2)http://picasaweb.google.com/lh/photo/4_gRWTa3CrcVl1de2O6tJNOn8JZBJKeOhX6kAQVvb9s?feat=directlink
Regards,
andrew
hand cranks?
andrew azman
+1.202.258.3951
Neil, thanks for the great information. Our current plan is to run a
pilot with 7 surveyors spread all over the country. Here's the
shopping list we've put together, would love to get feedback from the
group.
14 phones http://www.integrontech.com/ProductDetails.asp?ProductCode=HTC-G2-B&click=2
7 car outlets http://www.amazon.com/Duracell-813-0291-07-Pocket-Source-Inverter/dp/B000U0M7PG/
7 netbooks http://www.amazon.com/Toshiba-NB305-N410BL-10-1-Inch-Royal-Netbook/dp/B00303G9FO/ref=sr_1_4?ie=UTF8&s=electronics&qid=1280280536&sr=8-4
7 solar batteries with HTC adapter tip http://store.solio.com/Classic-i
We plan to procure outlet adapters and surge protectors locally. (This
goes against Neil's advice, which makes me a little worried.)
Thanks for the help, Andrew
> charge.
> Neil
>> hand cranks?
> ~Neil
For the ODK Aggregate, you will want to grab the latest 0.9.3 code (the
current development tip).
To restrict the access to your appspot, you'll want to modify
org.odk.aggregate.servlet.ServletUtilBase.java: verifyCredentials(...)
To test for specific users, etc.
The 0.9.3 code has support for a soon-to-be-released data downloading
function (ODK Briefcase) that can download all data in the Aggregate
instance to your hard drive as a set of binary data files and CSV files (one
CSV file for the top-level form data and one each for every repeated group
in the form).
On Tue, Aug 10, 2010 at 6:31 PM, Andrew Azman wrote:
Andrew,
in all conditions.
Here are a few photos to illustrate what they look like. (1)http://picasaweb.google.com/lh/photo/h9mXXsb6oMNi-KDiZkynvdOn8JZBJKeOhX6kAQVvb9s?feat=directlink and
Regards,
andrew
On Tue, Jul 27, 2010 at 8:06 PM, Andrew Marder andrew.n.marder@gmail.comwrote:
hand cranks?
andrew azman
+1.202.258.3951
The phones look good. Let us know how it goes with that supplier. I would
like to know if they are 32A or 32B.
The car outlets look fine for your purpose. If you are going to have 7
surveyors operating independently, they will only ever be recharging one
Android at a time. Maybe one netbook as well. If you were going to charge 7
phones at the same time in the same auto, you would need the USB hub and you
would need a more powerful version of the car outlet.
The netbooks look like they have a long battery life, that is very useful.
They are also cheap and have good reviews. Is it necessary for every
surveyor to have a netbook? Are they all doing seperate synch's? How are you
unifying your data?
You might consider using the Kobo Post Processor to synchronize your data
offline and transcribe it to CSV for import into your database.
I'm a big fan of the solio, it can be used when you don't have access to
your auto charger. We use the magnesium version, but I don't think there is
anything wrong with this version (classic) except that I think the capacity
of the battery is less than the capacity of the Android's battery, so it
will not charge an Android to 100%. You will have to check the specs.
If you are buying all this stuff in advance, why buy your adapters and surge
protectors in-country? It might work out fine, but I say that anything you
can fix in advance is worth taking care of before you are faced with the
challenges of shopping in a developing nation.
Looking forward to hearing more about your project,
Neil Hendrick
group.
14 phones
7 car outlets
7 netbooks
it's
from
we
whole
charge.
chargers.
I
home.
(to
try
the
give
100
2800
Neil
On Tue, Jul 27, 2010 at 3:06 PM, Andrew Marder < andrew.n.marder@gmail.com> wrote:
hand cranks?
☞§※⌘:airplane:
~Neil
☞§※⌘:airplane:
~Neil
A USB hub(s) are really really nice to have!
group.
charge.
Neil
On Tue, Jul 27, 2010 at 3:06 PM, Andrew Marder andrew.n.marder@gmail.com wrote:
hand cranks?
☞§※⌘:airplane:
~Neil
Hi All,
I just wanted to find out how your various trials have gone with the
Magics etc.
There's a bunch more HTCs out now (legend, incredible, desire) and was
wondering if a favourite in terms of usability and reliability had
emerged.
Also I was wondering if anyone had tried these rugged handsets from
Trimble? http://www.sdgsystems.com/index.php?option=com_content&view=article&id=93:android-on-nomad&catid=15:press-releases&Itemid=50
All the best,
Kieran
> in the form).
> Mitch
> > Andrew,
> > in all conditions.
> > Here are a few photos to illustrate what they look like. (1) and
> > (2)
> > Regards,
> > andrew
> >> hand cranks?
> > andrew azman
> > +1.202.258.3951
From the tech specs, it looks like the phones are 32B:
http://forum.smartdeviceresource.com/index.php?topic=100.0
Do you think it's worth spending more for 32A's?
I was thinking we'd use ODK Aggregate as close to out of the box as
possible. I think the only thing we'd need to set up is restricted
access on appspot, but I'd love some warning if I'm headed down the
wrong path. I'll definitely check out the Kobo Post Processor.
It seems that Solio has discontinued the magnesium version, kind of a bummer.
I totally agree, getting everything prepped now makes sense. Anyone
have a favorite converter for type D and G outlets?
Andrew
> unifying your data?
> Neil Hendrick
>> group.
>> 14 phones
>> 7 car outlets
>> 7 netbooks
>> > it's
>> > from
>> > fields, we
>> > We
>> > to
>> > whole
>> > to
>> > charge.
>> > chargers.
>> > outlet. I
>> > home.
>> > (to
>> > try
>> > the
>> > give
>> > 100
>> > 2800
>> > Neil
>> >> hand cranks?
>> > ~Neil
> ~Neil
32a has double the ram for the os which is nice if you want to
eventually run 2.2 via cyanogenmod. if you are running 1.5/1.6 i doubt
you'll notice.
as far as security, waylon just posted how to add security code to
aggregate at http://groups.google.com/group/opendatakit-implementers/browse_thread/thread/9da22e31e8e9b46a
> Andrew
>> unifying your data?
>> Neil Hendrick
>>> group.
>>> 14 phones
>>> 7 car outlets
>>> 7 netbooks
>>> > it's
>>> > from
>>> > fields, we
>>> > We
>>> > to
>>> > whole
>>> > to
>>> > charge.
>>> > chargers.
>>> > outlet. I
>>> > home.
>>> > (to
>>> > try
>>> > the
>>> > give
>>> > 100
>>> > 2800
>>> > Neil
>>> >> hand cranks?
>>> > ~Neil
>> ~Neil
This page explains the differences between 32A vs B, and how to tell.
http://wiki.cyanogenmod.com/index.php?title=How_to_determine_if_you_have_32A_or_32B
you'll notice.
aggregate at
bummer.
Andrew
would
charge 7
you
useful.
you
unifying your data?
data
is
capacity
surge
you
Neil Hendrick
group.
14 phones
7 car outlets
7 netbooks
and
it's
you
from
fields, we
recharging.
We
access
to
whole
sun
to
charge.
chargers.
outlet. I
home.
converters
(to
Don't
try
convert
the
give
buying
100
of
2800
data
Neil
survey
to
ODK
hand cranks?
☞§※⌘:airplane:
~Neil
☞§※⌘:airplane:
~Neil
We have both 32a and b and are running cyanogen 5.0.8. Out of 20 something we ended up bricking a few of the 32a 1.2 MyTouches (with the headphone jack on top) so I would stay away from them if possible.
you'll notice.
Andrew
unifying your data?
Neil Hendrick
group.
14 phones
7 car outlets
7 netbooks
it's
from
fields, we
We
to
whole
to
charge.
chargers.
outlet. I
home.
(to
try
the
give
100
2800
Neil
hand cranks?
☞§※⌘:airplane:
~Neil
☞§※⌘:airplane:
~Neil
