Hi? A quick question. How does one set up code book generator for it to
work? Any steps or prerequisite?
Louis..
Louis..
Hi Louis,
It should just be download
(http://linkssystem.org/support/Task-Force-LINKS-Codebook-v1.1.zip)
and double click. What happens when you do that?
Hi Yaw? I followed the link and downloaded. I unzipped the folder on my
desktop and took a photo. That is how looks like. Is something missing
which should be there?
Hi Louis,
and double click. What happens when you do that?Yaw
work? Any steps or prerequisite?Louis..
Hi Louis,
When you extract the zip file you should get a jar file named: LINKS
Codebook v1.1 (If on Windows try extracting the zip file using 7zip)
Run the jar file, it will ask you to select a form (xml file) and then run
code book.
Best and Regards
Ronald Munjoma
which should be there?On Sun, Sep 25, 2016 at 9:54 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi Louis,
Groups
an
Best and Regards
Ronald Munjoma
+263 775 625 283
[image: --]
Ronald Munjoma
[image: https://]about.me/ronaldmunjoma
https://about.me/ronaldmunjoma?promo=email_sig
I find this tool works best if you remove all but one language, and any
choice_filter column.
Hi Ronald? I don't see any jar file with the name you specified.
Louis...
Hi Louis,
Codebook v1.1 (If on Windows try extracting the zip file using 7zip)Run the jar file, it will ask you to select a form (xml file) and then run
code book.Best and Regards
Ronald MunjomaOn 26 September 2016 at 11:17, Louis Omoya louisomoya@gmail.com wrote:
Hi Louis,
Groups
an
Groups "ODK Community" group.
Best and Regards
Ronald Munjoma
+263 775 625 283[image: --]
Ronald Munjoma
https://about.me/ronaldmunjoma?promo=email_sig--
Hi Louis,
The thing you downloaded is what you want to double-click.
If double-clicking opens a folder like what you attached in your
earlier message, then you might not have Java installed. Install it at
http://www.java.com/en/download/index.jsp first.
should help.
Thanks. I will try this
Hi Louis,
http://www.java.com/en/download/index.jsp first.https://stackoverflow.com/questions/394616/running-jar-file-on-windows
should help.Yaw
Louis...
On Mon, Sep 26, 2016 at 1:33 PM, ronald munjoma simbiso@gmail.com wrote:
Hi Louis,
run code book.Best and Regards
my desktop and took a photo. That is how looks like. Is something missing
Hi Louis,
it towork? Any steps or prerequisite?
Louis..
Groups"ODK Community" group.
send anemail to opendatakit+unsubscribe@googlegroups.com.
Groups "ODK Community" group.To unsubscribe from this group and stop receiving emails from it,
send an email to opendatakit+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/d/optout.
Groups "ODK Community" group.To unsubscribe from this group and stop receiving emails from it, send
Best and Regards
Ronald Munjoma
+263 775 625 283Ronald Munjoma
about.me/ronaldmunjoma--
Hi? Thanks for suggestions. I installed Java.
I still downloaded code book v1.1. Still no jar folder
On Sep 26, 2016 5:35 PM, "Yaw Anokwa" yanokwa@nafundi.com wrote:
Hi Louis,
should help.Yaw
Louis...
Hi Louis,
Hi Louis,
Louis..
Best and Regards
Ronald Munjoma
Hi Louis,
I just downloaded the zip file on Windows 10. I extracted it. I
double-clicked it, and it launched. Attached is a screenshot.
What operating system are you using? What precise steps have you
taken? What has happened when you've done those steps?
Hi?
My operating system is Windows 8; 32 bit operating system, x64 based
processor . I don't have jar file in the unzipped folder
Hi Louis,
double-clicked it, and it launched. Attached is a screenshot.What operating system are you using? What precise steps have you
taken? What has happened when you've done those steps?Yaw
I still downloaded code book v1.1. Still no jar folderOn Sep 26, 2016 6:37 PM, "Louis Omoya" louisomoya@gmail.com wrote:
Hi Louis,
should help.Yaw
Louis...
Hi Louis,
thenrun code book.
Best and Regards
onmy desktop and took a photo. That is how looks like. Is something
missingwhich should be there?
Hi Louis,
v1.1.zip)and double click. What happens when you do that?
forit to
You received this message because you are subscribed to the
Groups
it,send an
Best and Regards
Ronald Munjoma
sendan email to opendatakit+unsubscribe@googlegroups.com.
Louis,
Make sure you have file extensions enabled.
http://www.laptopmag.com/articles/show-file-extensions
If it helps, you can upload a screenshot to http://pasteboard.co and
send out a link.
