Collect auto-send working for offline data
Assuming the collect app is working in offline mode and forms are queued on the device, waiting for the internet availability with auto-send enabled, does the app needs to be running in the foreground/background for internet detection and data exchange? What if the collect app is not running, or the phone is restarted (or something similar where collect is not active)? Would the forms be sent then too, or do we have to tell the field officer to open the app and only then the auto-send will work?
Saad
Hi @Saad
Auto-send does not require ODK Collect to remain open. When a form is finalized while the device is offline, it is queued locally and Collect will send it when a suitable network connection becomes available. This is designed to work even when Collect is not running, so the field officer should not normally need to reopen the app.
Pending submissions should also resume automatically after a device restart (once the phone is unlocked), without opening Collect. Note that Android may defer background tasks to save battery, so submissions might not be sent the moment the connection returns.
One important exception is when Collect has been force-stopped. In that case, Android won't run its background tasks until the app is opened again. Some manufacturers (e.g. Xiaomi, Huawei, Oppo) apply aggressive battery optimizations with a similar effect, so on such devices it's worth disabling battery optimization for Collect.
