Hello,
I have created a form with a grid of icons like the attached image
device-2012-02-09-174110.png. I was wandering if it possible:
- When you click one of the icons, to collect the gps location and save
the form.
for example if we have 4 icons, a school, a church, a house and a
hospital and the
user press the hospital icon, I would like to collect the gps location
and save the form. - When an icon is pressed and the location is collected the form should
be saved without
asking the user and then if it is possible for the form to run again,
without the user having
to go to "Fill Blank Form" and then select my form. - Is it possible to remove the first stage at the form where it writes
"You are at the start of
"Form name". Swipe the screen as shown below to begin" (attached image
device-2012-02-09-174110.png)?
Thanks in advance.
My regards,
Michalis
