bosoin d'aide
SVP comment integrer l'api ODK dans une application android je sais pas si
il ya possibilite ou non et comment je peux trouver le code de source
d'ODK
Merci d'avance pour votre reponse
Fadwa,
Collect overview:
https://code.google.com/p/opendatakit/wiki/CollectSourceCodeOverview
ODK code: https://code.google.com/p/opendatakit/wiki/SourceTab?tm=4
Data transfer APIs: http://opendatakit.org/use/aggregate/data-transfer/#APIs
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Mon, Mar 24, 2014 at 8:23 AM, Fadwa Elyakoubi elyakoubi.fadwa@gmail.com wrote:
bosoin d'aide
d'ODK
Merci d'avance pour votre reponse--
"ODK Developers" group.
ODK Tables initializes and launches ODK Collect. Either with a pre-defined
form, or on-the-fly with a very simple dynamically constructed form.
The editRow() method launches ODK Collect --
http://code.google.com/p/opendatakit/source/browse/src/org/opendatakit/tables/activities/Controller.java?repo=tables#411
And uses the functions here
http://code.google.com/p/opendatakit/source/browse/src/org/opendatakit/tables/utils/CollectUtil.java?repo=tables
On Mon, Mar 24, 2014 at 10:31 AM, Yaw Anokwa wrote:Fadwa,
Collect overview:
Data transfer APIs:
http://opendatakit.org/use/aggregate/data-transfer/#APIsYaw
bosoin d'aide
si
d'ODK
