Como Agregar formulario
Alguien me puede ayudar indicándome como publico el formulario en
ifrc-padru.appspot.com.
Afradezco su atención.
Saludos,
You can access this server via ODK Collect and download forms from it
anonymously. If you want to prevent anonymous submissions, remove the Data
Collector permission from the anonymous user (via the Site Admin /
Permissions tab).
The anonymous user does not have Data Viewer permissions; this causes the
login screen to be presented before the website is displayed. You must log
in as a user having Data Viewer permissions to access the website.
When using ODK Briefcase, to pull data off of a server, you must have at
least Data Viewer permissions, and to push data up to a server, you will
need Form Manager permissions on the server.
··· ------------ If you open an incognito window and go to this url: https://ifrc-padru.appspot.com/xformsList you will see the list of forms available on the server to an anonymous user. If your server does not grant Data Collector privileges to the anonymous user, this URL will redirect to the login page.
On Tue, Mar 31, 2015 at 2:15 PM, Adriana Herrera <l.adrianaherrera@gmail.com wrote:
Saludos,
Muchas gracias por su información, pero sigo sin poder entrar, cuando
ejecuto ODK Collect me solicita email y password pero cuando incluyo los
datos de la cuenta de correo electrónico de Gmail no me permite accesar,
que puedo hacer para solventar esto?
Agradezco su valiosa ayuda.
Saludos.
Saludos,
You must specify an ODK Aggregate username and password.
ODK Collect does not use the email account when submitting to ODK
Aggregate; it uses the ODK username and password.
··· 2015-04-01 6:07 GMT-07:00 Adriana Herrera :
Saludos.
Saludos,
A post was split to a new topic: AppEngine Application Problem : Exceeded its per-minute or daily usage quotas
