I have changed the branch to uiexperiment as you suggested, I now have this
error when i try to compile;
[ERROR] Failed to execute goal
org.apache.maven.plugins:maven-compiler-plugin:3.0:compile
(default-compile) on project aggregate-src: Compilation failure:
[ERROR]
/C:/workspace/survey.aggregate/src/main/java/org/opendatakit/aggregate/server/ServerDataServiceImpl.java:[24,31]
package org.apache.commons.lang does not exist
[ERROR]
[ERROR]
/C:/workspace/survey.aggregate/src/main/java/org/opendatakit/aggregate/server/ServerDataServiceImpl.java:[303,15]
cannot find symbol
[ERROR] symbol: class NotImplementedException
[ERROR] location: class
org.opendatakit.aggregate.server.ServerDataServiceImpl
[ERROR]
/C:/workspace/survey.aggregate/src/main/java/org/opendatakit/aggregate/server/ServerDataServiceImpl.java:[334,15]
cannot find symbol
[ERROR]
/C:/workspace/survey.aggregate/src/main/java/org/opendatakit/aggregate/server/ServerDataServiceImpl.java:[532,15]
cannot find symbol
The requested package is defined in the pom file and its also in the m2
repository, perhaps you can help me fix this.
Yup. Apparently a bad check-in. I'll try to get something that will build
checked in sometime today.
On Wed, Sep 25, 2013 at 1:20 PM, Kwame Bentil wrote:
Dear Mitch,
this error when i try to compile;
[ERROR]
[ERROR]
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
On Wed, Sep 25, 2013 at 1:20 PM, Kwame Bentil kwame@imagead.net wrote:
Dear Mitch,
[ERROR]
[ERROR]
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
Regards,
Kwame
"ODK Developers" group.
Kwame Bentil
System Designer / MD
Image-AD
m: +233 (0)26 438 4557
t : +233 (0)30 230 3053
DISCLAIMER: This email and any attachments are confidential and are
intended solely for the addressee. If you are not the addressee tell the
sender immediately and destroy it. Do not open, read, copy, disclose, use
or store it in any way, or permit others to do so. Emails are not secure
and may suffer errors, viruses, delay, interception, and amendment.
Image-AD and its subsidiaries do not accept liability for damage caused by
this email and may monitor email traffic.
I was able to resolve dependency issue by added this to pom, as this
version has class NotImplementedException implemented;
commons-lang
commons-lang
2.6
However I have another error, sample below;
org.apache.maven.plugins:maven-compiler-plugin:3.0:testCompile
(default-testCompile) on project aggregate-mysql: Compilation failure:
[ERROR]
/C:/workspace/survey.aggregate/src/it/java/org/opendatakit/aggregate/odktables/api/perf/CreateTableTest.java:[14,62]
cannot find symbol
[ERROR] symbol: class ColumnType
org.opendatakit.aggregate.odktables.rest.entity.Column
[ERROR]
/C:/workspace/survey.aggregate/src/it/java/org/opendatakit/aggregate/odktables/api/T.java:[42,84]
cannot find symbol
[ERROR] symbol: variable ColumnType
[ERROR] location: class org.opendatakit.aggregate.odktables.api.T.Columns
These classes are importing
org.opendatakit.aggregate.odktables.rest.entity.Column.ColumnType, but
ColumnType method or class is not defined anywhere in column class, do I
need to pull new files?
Kwame
Dear Mitch,
[ERROR]
[ERROR]
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
Regards,
Kwame
an email to opendatakit-developers+unsubscribe@googlegroups.com.
Kwame Bentil
Image-AD
Kwame Bentil
Image-AD
I got it working I have done quick test of the json server, works
perfectly. Will continue to do more test and give you feedback.
Thanx
Kwame
On Thu, Sep 26, 2013 at 11:49 AM, Kwame Bentil wrote:
Dear Mitch,
commons-lang
commons-lang
2.6
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
Kwame
build checked in sometime today.
Dear Mitch,
[ERROR]
[ERROR]
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
Regards,
Kwame
Kwame Bentil
Image-AD
Kwame Bentil
Image-AD
Kwame Bentil
Image-AD
Note that the javarosa library is now using a datestamp a its version, so
you will need to run the "mvn install:install-file
-Dfile=javarosa-libraries-2013-08-08.jar..." command to install it. The
full command is in the src/main/libs/readme.txt
This assumes the 1.8.0 AppEngine SDK and selenium 2.33.0, so if you are
building via Maven, you'll want to update your .m2/settings.xml and/or
download that version of selenium.
There are database changes, so if you are running on MySQL or PostgreSQL,
you will need to either drop your database or look for the start-up errors
and drop each table that has a problem so that it can be recreated.
On Thu, Sep 26, 2013 at 2:29 PM, Kwame Bentil wrote:
Hi Mitch,
Thanx
Kwame
On Thu, Sep 26, 2013 at 11:49 AM, Kwame Bentil kwame@imagead.net wrote:
Dear Mitch,
commons-lang
commons-lang
2.6
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
Kwame
On Wed, Sep 25, 2013 at 1:20 PM, Kwame Bentil kwame@imagead.netwrote:
Dear Mitch,
[ERROR]
[ERROR]
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
m2 repository, perhaps you can help me fix this.
Regards,
Kwame
Kwame Bentil
Image-AD
Kwame Bentil
Image-AD
Kwame Bentil
Image-AD
