To correct problems introduced by the googlecode migration, we have
recreated our GitHub repositories:
For each *projectname *(e.g., collect, tables, aggregate, etc.):
The GitHub repository for that project that was created prior to August 21,
3:50 PDT and named *projectname *==has-been-renamed-to==> projectname-bad
And the corrected GitHub repository for that project that was previously
known as projectname-fixed ==has-been-renamed-to==> projectname
Now that the renaming is complete, if you have cloned the repositories and
modified the code, you will want to follow these instructions to rebase
your clone to the new project repository:
We will be removing all "projectname-bad" repositories from Github in one
week. If you are still working from one of those repositories, please use
the migration path linked in the previous message or make your own fork.
This does not affect the normal repositories under active development. If
you are developing against collect, this will not affect you. If you are
developing against collect-bad, you need to migrate to collect.
We will be permanently deleting these repositories on Tuesday, November 10.
Please make plans accordingly.
Jeff Beorse
> 21, 3:50 PDT and named *projectname *==has-been-renamed-to==>
> *projectname-bad*
> known as *projectname-fixed* ==has-been-renamed-to==> *projectname*
> https://github.com/opendatakit/opendatakit/wiki/New-Repository-Migration-Guide
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
