I'm trying struggling to build the correct syntax for the following scenario. I'm using the Survey123 Connect app (vers 3.7.62) to push out to a DT rugged field tablet.
I have 5 possible measurements DBH1, DBH2, DBH3, DBH4, DBH5.
DBH1 will never be a NULL value but the subsequent DBH values may be null.
From there my calculation is =SQRT((DBH1^2)+(DBH2^2)+(DBH3^2))...
Screenshots below show my calc's
I also cannot get the pulldata funxtion to populate the final question.
I have tried to break this down into simple steps firstly and then build up to more complicated expressions.
The only result I could get for SumDBH was 3 and it should've been 25.
I'm new to the ODK group so.... Hi Everyone! I hope you can help me I've spent soooo much time on trying to work this out myself.
Hi @awright,
Best to check with Survey123 support. There is some overlap between ODK and Survey123 but quite a few differences too.
(P.S. in ODK world exp()
always has only 1 parameter, and pulldata()
always has 4, so check the Survey123 documentation about those functions. I think you want use pow()
instead of exp()
Thanks for your reply Martin. I have found the Survey123 documentation to be a bit light on for complex formulas but thanks for the heads up.
So back to my question if any else can possibly help me on this. I can break it down to its simplest parts and then build up to more complex formulas
IF DBH1 is NOT NULL and I want to add DBH1 to subsequent DBH values if they also are NOT NULL what would that formula look like?
Also I would like to populate the X and Y coordinates in my table for export as a shapefile back into the GIS. I thought the pulldata function would do this but as you mentioned above i must have 4 parameters?
