Concatenating labels of previous questions?
I am using xlsforms due to absolutly no coding background but I have been
able to get a nice workable survey form working with this
technology........very cool but I have ran into something I cannot find an
answer for
I have a series of three questions that I would like to reference the label
rather than the name of the field to be used as an entry into a note field
separated by commas.
text question1 label1
text question2 label2
text question3 label3
note concat1 question1.label1,question2.label2,question3.lablel3
if you cant tell i am a database guy..........hence the table.column
reference.
how can this be done?
John,
Use jr:choice-name() to show the label instead of value.
http://opendatakit.org/help/form-design/binding has more details and
https://groups.google.com/d/msg/opendatakit/gRdvgUR7mfA/WHHi9XJpzckJ
has an example with a workaround for a common gotcha.
ยทยทยท -- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.
answer for
reference.
