Hi
I want to concatenate 2 strings taken as text type whose values have been
filled in the previous questions.
I am able to do it in the label(${field1}${field2}) of the field, but not
able to get it as a value in the text field of the current one.
Example
Field1 First Name - abc
Field2 Last Name- xyz
Field 3 Full Name - Desired Result(abcxyz)
Please help me out with this.
yanokwa
2
Jaitin,
Add a calculate attribute to full name where
calculate="concat(${first}, ' ',${last})".
Need ODK services? http://nafundi.com provides form design,
professional support, custom reporting, and software development for
ODK.
On Sun, Sep 8, 2013 at 8:11 AM, Jatin Thapar jatin10033@iiitd.ac.in wrote:
Hi
Example
cece
3
I would like to thank you so much Yanokwa. I will set code and see on display then let you know if two texts are separated now.
Have a good day
