I am trying to create a new project in google cloud, but now this platform suggest me that i need to deploy my application in a different way and i confuse because i don't know, what i should be do to create it and sync with aggreagte.
version v1.6.1 in android devices.
I create the project and the application, download the java jdk and try using cloud shell, but i can't get a url for my application and compute engine configuration, i need to redirecting to odkaggregate.
