I am getting a 406.1 error code (unacceptable requested format) when I try to connect to the submit data using my project's api odata code.
odk central 1.2
google chrome Version 91.0.4472.114 (Build officiel) (32 bits)
Looked around the ODK Central and in documentation. I could not find it anywhere.
N/A
N/A
Welcome to the ODK forum, @GAMPINI! We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a picture as your avatar because it helps build community!
The OData feed is intended primarily for connecting to submission data (that is, for analysis and visualization), and not for submitting data. What is your use case that you are trying to submit data using the "project's API OData code"? Most people submit using either the Android app ODK Collect or Enketo web forms in their browser.
hello @danbjoseph ,
Thanks for the answer, I'm happy to be here. I wanted to retrieve the data which was submitted directly by entering the code in the url of the browser but after having read the documentation I saw that it is necessary to be authenticated to have access to the information of my project. so i implemented this code in php, but i got an error message: {"message":"Required parameter form ID xml attribute missing.","code":400.2,"details":{"field":"form ID xml attribute"}}
<?php
// authentification
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "https://xxxxxxxxxxxxxxx/v1/sessions");
curl_setopt($ch, CURLOPT_RETURNTRANSFER, TRUE);
curl_setopt($ch, CURLOPT_HEADER, FALSE);
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($ch, CURLOPT_POST, TRUE);
curl_setopt($ch, CURLOPT_POSTFIELDS, "{
\"email\": \"xxxxxxxxxxxxxx@xxxxxx.com\",
\"password\": \"xxxxxxxxxxxxxx\"
curl_setopt($ch, CURLOPT_HTTPHEADER, array(
"Content-Type: application/json"
$response = curl_exec($ch);
var_dump($response);
$json = json_decode($response, true);
$Authorization= "Authorization: Bearer ".$json['token']."";
$url = "xxxxxxxxxxxxxxxxx/v1/projects/1/forms/xxxxxxxxx.svc/Submissions";
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
$headers = array(
$Authorization
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$resp = curl_exec($ch);
curl_close($ch);
var_dump($resp);
Is the .svc
in your URL part of the xmlFormID for the form you are trying to access? Or is that something you're adding on?
my xmlFormID is : id="infoperso",
I was inspired by the example in the API documentation : infoperso.svc
<?php
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "https://private-948d41-odkcentral.apiary-mock.com/v1/projects/projectId/forms/{xmlFormId}.svc/{table}?%24skip=&%24top=&%24count=&%24wkt=&%24filter=&%24expand=");
curl_close($ch);
Hi @GAMPINI! I'm not familiar with PHP, but from your code above, it looks like the HTTP verb might still be POST in the second request. The request to the OData endpoint should use GET.
