Hello,
Can we anyhow connect to backend of ODK bypassing ODK aggregate after
creating appinstance on appspot.com
Hello,
Not sure what you mean?
Do ODK Aggregate can run on appspot.com. What other backend are you refering to?
Waylon
How to publish data to google fusion tables. It gives an error invalid
token or Login error.
refering to?Waylon
On Sun, Apr 8, 2012 at 10:38 PM, Madhur Hasija madhurh@iiitd.ac.in wrote:
Hello,
creating appinstance on appspot.com--
Regards
Madhur
9718345506
Regards
Madhur
9718345506
Google Fusion tables had a change in their credential management so it
now eventually times out.
The main reason for the ODK Aggregate 1.0.6 release was to fix this issue.
--Added a Refresh Credentials button on publishers. This button
appears when the publishing to an external service (Google Spreadsheet
or Fusion Tables) fails with a 401 (Unauthorized) error. Clicking the
button will walk through the authorization screens for publishing to
that service, yielding a new credential for that publisher.
Here is the issue history if you are interested.
http://code.google.com/p/opendatakit/issues/detail?id=542.
Cheers,
Waylon
