Greetings Forum, I have a problem when trying to send a test form to the server ODK Aggregate through the ODK Build. The version of the server Aggregate is 1.5.0 and I have Tomcat 8 installed on this. The server is a virtual machine on VirtualBox. Other features such as ODK Collect work perfectly. Could you help me? Thank you...
Hello dear, I 've never used this option but one question I'd like to ask you: are you using SSL security? because I see you indicated https. If you don't have SSL licence pleas change it to http only.
Could you post here the error, pleas?
If you are doing a deployment, the first option is probably best. If you are just testing things, go with the second option because it should be easier.
