Hello,
I need help.
In xls form how to do so that the date of circumcision does not precede the date of birth in xls form? What to put in constraint?
in the constraint column put .>= ${date_of_birth}
you will need to replace date_of_birth with whatever you called the date of birth question in the name field. its best if you add an explanation in the constraint_message column if possible as well
Hello
Thanks for the rapide answer.In my xls form, i replace date_of_birth by date_nais by doing .>= ${date_of_birth} in the colomn constraint at the line 291 but it doesn't work. ![SCREAN|690x251]
(upload://lhrAmIomM431UNROiAsBsDnTBzr.png)
Hi Bilal,
Sorry your image doesnt show, you may need to attach the excel for us to understand if you havent already resolved the issue.
