Hi all,
I would like to ask a question (yes or no) and then if yes - require
answers (something entered) to subsequent string question, if no - dont
allow anything to be entered in the subsequent string question.
I know I can hide/skip using "relevant" but i want to keep the questions
on the same page so I hope to find a a way to use "constraint".
Could anyone feeling generous hint at what the constraint might look like
for if variablea is yes -- require answer to next question, if variablea is
no -- dont allow an answer to the next question ?
Many thanks!
Bill
You would have to have two conditions, required, and constraint
required = "selected(${yq_q},'yes')" -- to make sure that the question
is answered if it is yes
constraint = "if( selected(${yn_q},'yes'),string-length(.) > 0,
string-length(.) = 0)" -- if the answer is yes, we have an
non-zero-length answer, otherwise, we have a zero-length answer
On Wed, Jun 5, 2013 at 3:42 PM, Bill Olander wrote:Hi all,
like for if variablea is yes -- require answer to next question, if
variablea is no -- dont allow an answer to the next question ?
Many thanks!
Bill--
I would like to do the same thing but am using the xls form as I am not a
programer. Are the two conditions entered in the same form using the xls
development path?
Thank you,
Sarah
On Wednesday, 5 June 2013 15:42:11 UTC-7, Bill Olander wrote: > > Hi all, > I would like to ask a question (yes or no) and then if yes - require > answers (something entered) to subsequent string question, if no - dont > allow anything to be entered in the subsequent string question. > I know I can hide/skip using "relevant" but i want to keep the questions > on the same page so I hope to find a a way to use "constraint". > Could anyone feeling generous hint at what the constraint might look > like for if variablea is yes -- require answer to next question, if > variablea is no -- dont allow an answer to the next question ? > Many thanks! > Bill >thanks mitch!
On Wednesday, June 5, 2013 11:23:50 PM UTC, Mitch Sundt wrote: > > You would have to have two conditions, required, and constraint > > required = "selected(${yq_q},'yes')" -- to make sure that the question > is answered if it is yes > constraint = "if( selected(${yn_q},'yes'),string-length(.) > 0, > string-length(.) = 0)" -- if the answer is yes, we have an > non-zero-length answer, otherwise, we have a zero-length answer > > > > > On Wed, Jun 5, 2013 at 3:42 PM, Bill Olander <billyo...@gmail.com wrote: > >> Hi all, >> I would like to ask a question (yes or no) and then if yes - require >> answers (something entered) to subsequent string question, if no - dont >> allow anything to be entered in the subsequent string question. >> I know I can hide/skip using "relevant" but i want to keep the >> questions on the same page so I hope to find a a way to use "constraint". >> Could anyone feeling generous hint at what the constraint might look >> like for if variablea is yes -- require answer to next question, if >> variablea is no -- dont allow an answer to the next question ? >> Many thanks! >> Bill >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/groups/opt_out. >> >> >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >Hi Sarah,
Yes, those expressions are the ones for .xls format (because they use the
${fieldname} syntax to refer to fields). You just put the expressions into
the required and constraint columns of your worksheet.
Chris
On Thu, Jun 13, 2013 at 1:56 AM, Sarah Pfeil wrote:I would like to do the same thing but am using the xls form as I am not a
development path?
Thank you,
SarahOn Wednesday, 5 June 2013 15:42:11 UTC-7, Bill Olander wrote:
Hi all,
Many thanks!
Bill--
