will someone please help me. I've also googled old discussions, but can't
find it. I think this should be straight forward, but I can't figure out
how to script the following constraint. One one screen, I have three fields
-- Total, A, B.
I want to add a constraint, that says that Total has to be a sum of A & B.
Assuming the nodeset names are form/Total, form/B, etc., what is the
syntax??
-- Total, A, B.
syntax??
fields
-- Total, A, B.
B.
syntax??
Similar question so I'm adding here instead of starting a new thread.
My form is asking for household headcounts in divided by Adult_Male,
Adult_Female, and children in 3 age groupings. (total of 5 fields)
After these 5 questions I want an acknowledgement screen for accuracy
control
In the DISPLAY of this field, I would like it to calculate and display the
total of the 5 headcount questions,
Can I have an acknowledgement button AND a displayed calculation together?
Does the calculate function belong inside the output value in the label??
On Thursday, September 19, 2013 1:34:55 PM UTC-4, Jitka Hiscox wrote:
> Thanks Yaw!
> On Thu, Sep 19, 2013 at 11:24 AM, Yaw Anokwa <yan...@nafundi.com wrote:
>> Hi Jitka,
>> You should consider automatically calculating the total so the user
>> does not have to enter it.
>> If you want manual totaling, the below code should work in a constraint.
>> constraint="(/data/a + /data/b) eq /data/total"
>> Yaw
>> Need ODK services? http://nafundi.com provides form design,
>> professional support, custom reporting, and software development for
>> ODK.
>> On Tue, Sep 17, 2013 at 1:32 PM, Jitka Hiscox <jitka....@gmail.com> wrote:
>> > Hi all,
>> can't
>> out
>> fields
>> > -- Total, A, B.
>> B.
>> > syntax??
>> > constraint=("form/Total" = ....
>> > I will be very grateful for your help.
>> > j
>> > Post: opend...@googlegroups.com
>> > Unsubscribe: opendatakit...@googlegroups.com
>> > Options: http://groups.google.com/group/opendatakit?hl=en
>> > You received this message because you are subscribed to the Google
>> Groups
>> > "ODK Community" group.
>> > To unsubscribe from this group and stop receiving emails from it, send
>> an
>> > email to opendatakit...@googlegroups.com .
>> > For more options, visit https://groups.google.com/groups/opt_out.
Ok, this is weird of me, but I'm going to post the answer to my own
question here, because I kept trying different things and got it to work.
In the Total field, include an output value in the label (display)
Is there a total of people
in this household?
the calculation goes in the binding:
and lastly, you have to use "trigger ref " in the body
I build forms with the odk build tool, but anyone who uses different tools
can probably apply this info to their format.
> control
>> Thanks Yaw!
>> On Thu, Sep 19, 2013 at 11:24 AM, Yaw Anokwa wrote:
>>> Hi Jitka,
>>> >> type="decimal"/>
>>> Yaw
>>> ODK.
>>> On Tue, Sep 17, 2013 at 1:32 PM, Jitka Hiscox wrote:
>>> > Hi all,
>>> can't
>>> out
>>> fields
>>> > -- Total, A, B.
>>> & B.
>>> > syntax??
>>> > j
>>> Groups
>>> an
>>> > email to opendatakit...@googlegroups.com.
>>> Groups "ODK Community" group.
>>> an email to opendatakit...@googlegroups.com.
