Is there an easy way to require the enumerator to enter in a value for
every question on ODK Collect? That is, I want it to be such that you
cannot advance in the survey without answering every question. I've tried
placing constraints on the values, but this only has an effect if the you
input some value for the question (i.e. if the constraint is " .>0 and
.<=150 ", an entered value of 200 will prevent movement to the next screen,
but when no value is entered, you can proceed to the next screen).
Is there an easy way to require the enumerator to enter in a value for every
question on ODK Collect? That is, I want it to be such that you cannot
advance in the survey without answering every question. I've tried placing
constraints on the values, but this only has an effect if the you input some
value for the question (i.e. if the constraint is " .>0 and .<=150 ", an
entered value of 200 will prevent movement to the next screen, but when no
On Thursday, February 6, 2014 12:26:12 AM UTC-5, Yaw Anokwa wrote:
> Hi Melanie,
> You can make the prompt required. See the bottom of
> http://opendatakit.org/help/form-design/binding/ for an example of a
> required integer in XML.
> If you are using XLSForm, you can add a true() to the required column
> of the prompt. See http://opendatakit.org/help/form-design/xlsform for
> an example form.
> Yaw
> Need ODK services? http://nafundi.com provides form design, server
> setup, professional support, and software development for ODK.
> On Thu, Feb 6, 2014 at 2:30 AM, Melanie Wallskog <nicara...@gmail.com > wrote:
> > Hi all,
> every
> placing
> some
> no
> > Thanks!
> > Melanie
> Groups
> > "ODK Community" group.
> an
> > For more options, visit https://groups.google.com/groups/opt_out.
