Consultation about hyphens use
Hello Forum
At the moment I have elaborated a template for the data collection of people. However, I have a problem to enter identification data separated by hyphens, because in some cell phones that we use with the ODK collect v1.12.2, the entry of hyphens is not enabled.
How can I solve this problem?
Is there a way to enter a data entry mask so that you only have to type numbers and the scripts appear automatically?
I hope you can help me
Thank you very much
regards
Roberto
Hi @roanjize
Can't you use a text widget instead of integer?
Regards,
Grzegorz
Hi
Yes, that´s probably apractical solution
I will prove it
Thanks Grzegorz
Regards
