I have a html form that allows me to select a userid and redirect to a
sales html form with the Rowid (guid) passed through the querystring. I
then want to access some information about that user on the new page but i
cannot query the user table based upon this RowId
I tried control.query and used '_uri' as the search field, but that throws
an error - so how am i able to query the table based upon a known RowId?
In ODK 2.0, the instanceId / rowId is in the _id column (this is a change
from the naming of columns in the 1.x data tables in ODK Aggregate).
> On Thu, Dec 17, 2015 at 5:32 AM, Andrew de Klerk <andrew....@gmail.com > wrote:
>> throws an error - so how am i able to query the table based upon a known
>> RowId?
>> Thanks
>> Andrew
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
i.e. it is only the fields we have added in the form design. I am trying to
do the following to get a record of the entire row for that user based upon
their id (guid):
var userlist = control.query(
'user',
'_id = ?',
[userid]);
I hope this makes sense
>> RowId?
>> Thanks
>> Andrew
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
as a solution we have created our own auto-incrementing user id and are
using that. I would still be interested to know if what i wanted to do is
still possible
On Friday, 18 December 2015 11:00:28 UTC+2, Andrew de Klerk wrote:
> Hi Mitch
> I am still not having any joy. If I say:
> data.getColumns()
> I get
> "{"mobile_main":"String","town":"String","wakala":"String","mobile_1":"String","user_type":"String","surname":"String","name":"String","village":"String"}"
> to do the following to get a record of the entire row for that user based
> upon their id (guid):
> 'user',
> '_id = ?',
> [userid]);
>>> RowId?
>>> Thanks
>>> Andrew
>>> Groups "ODK Community" group.
>>> an email to opendatakit...@googlegroups.com.
>> Mitch Sundt
>> Software Engineer
>> mitche...@gmail.com
You should be able to call userlist.getColumns() based on your previous
example. Are you encountering an error when you do this?
Clarice
still possible
'user',
'_id = ?',
[userid]);
change from the naming of columns in the 1.x data tables in ODK Aggregate).
RowId?
That request above throws an error, but if I change the query to "surname"
and "xyx" and then run userlist.getColumns() then I get the same set of
columns. As mentioned, we have made a workaround by creating our own id.
Not ideal, but satisfactory enough
Andrew
> Clarice
> On Fri, Dec 18, 2015 at 4:14 AM, Andrew de Klerk <andrew....@gmail.com > wrote:
>> still possible
>>> Hi Mitch
>>> data.getColumns()
>>> I get
>>> 'user',
>>> '_id = ?',
>>> [userid]);
>>>>> RowId?
>>>>> Thanks
>>>>> Andrew
>>>> Mitch Sundt
>>>> Software Engineer
>>>> mitche...@gmail.com
