I cannot figure out why I am getting this error which did not persist prior. All the libraries have been added and there are no errors being displayed however at run time I get this error:
UNEXPECTED TOP-LEVEL EXCEPTION:
com.android.dx.cf.iface.ParseException: class name (au/com/bytecode/opencsv/CSVParserTest) does not match path (target/test-classes/au/com/bytecode/opencsv/CSVParserTest.class)
at com.android.dx.cf.direct.DirectClassFile.parse0(DirectClassFile.java:520)
at com.android.dx.cf.direct.DirectClassFile.parse(DirectClassFile.java:406)
at com.android.dx.cf.direct.DirectClassFile.parseToInterfacesIfNecessary(DirectClassFile.java:388)
at com.android.dx.cf.direct.DirectClassFile.getMagic(DirectClassFile.java:251)
at com.android.dx.command.dexer.Main.processClass(Main.java:665)
at com.android.dx.command.dexer.Main.processFileBytes(Main.java:634)
at com.android.dx.command.dexer.Main.access$600(Main.java:78)
at com.android.dx.command.dexer.Main$1.processFileBytes(Main.java:572)
at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:284)
at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:166)
at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144)
at com.android.dx.command.dexer.Main.processOne(Main.java:596)
at com.android.dx.command.dexer.Main.processAllFiles(Main.java:498)
at com.android.dx.command.dexer.Main.runMonoDex(Main.java:264)
at com.android.dx.command.dexer.Main.run(Main.java:230)
at sun.reflect.GeneratedMethodAccessor24.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.android.ide.eclipse.adt.internal.build.DexWrapper.run(DexWrapper.java:187)
at com.android.ide.eclipse.adt.internal.build.BuildHelper.executeDx(BuildHelper.java:786)
at com.android.ide.eclipse.adt.internal.build.builders.PostCompilerBuilder.build(PostCompilerBuilder.java:597)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:321)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:396)
at org.eclipse.core.internal.resources.Project$1.run(Project.java:618)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:597)
at org.eclipse.core.internal.resources.Project.build(Project.java:124)
at com.android.ide.eclipse.adt.internal.project.ProjectHelper.doFullIncrementalDebugBuild(ProjectHelper.java:1116)
at com.android.ide.eclipse.adt.internal.launch.LaunchConfigDelegate.launch(LaunchConfigDelegate.java:147)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:855)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:704)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1047)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1251)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
...while parsing target/test-classes/au/com/bytecode/opencsv/CSVParserTest.class
[2013-12-26 12:29:03 - ODK Collect] Dx 1 error; aborting
[2013-12-26 12:29:03 - ODK Collect] Conversion to Dalvik format failed with error 1
Are you using the tip of the default branch for ODK Collect?
The opencsv.jar that was initially checked in was corrupted (it included
the test files such as the one you are getting an error about).
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
...while parsing
with error 1
