I am using a pre-populated data set and inputting a date of birth, the
values are in 'YYYY-MM-DD' format. I can see the display of the value after
reading from the data set, e.g. '2011-05-25'. But when I convert to date
format using command date(${field1}), the output field displays blank.
I want to compare the date field with today() so to count the number of
days.
Can anyone please suggest how to convert into date format.
Surajit
Hi Surajit,
Try the format-date() command described at
https://opendatakit.org/help/form-design/binding.
days.
Surajit
