Am getting this error message "Error: The survey sheet is either empty or missing important column headers." when I try converting an XLS form to XForm. 2. What app or server are you using and on what device and operating system? Include version numbers.
Am using windows operating system 3. What you have you tried to fix the problem?
I have not tried to fix it as I dont have an idea how to do it. 4. What steps can we take to reproduce the problem?
I have the same problem.
My sheet is correctly called "survey"
The three column headers Type, Name and Label are present
Still get the same error
Very frustrating
I fixed the labels, but have a new problem.
With KoboToolbox chosen as the server - I can submit forms without a problem.
However, with Google Drive chosen I get an error that reads:
"Upload Results
Unable to make API calls. If you are running a local build, please review the project readme"
Please help
