Hello ODK Community,
Is there any way to copy paste groups of questions in build? I tried
selecting a question and using the copy from the drop down menu but it
doesn't work.
Rachel
doesn't work.
Rachel
Rachel,
Nope. What high level goal are you trying to accomplish?
doesn't work.Rachel
if i have a list of questions that vary only slightly in wording and the
question number I want to be able to copy paste a question so I don't have
to re-input all of the parameters.
Hi Rachel,
Your best bet is to switch to XLSForm. Build was designed to proved
very basic (and thus easy to use) functionality.
to re-input all of the parameters.On Friday, March 21, 2014 10:28:19 AM UTC-7, Yaw Anokwa wrote:
Rachel,
setup, professional support, and software development for ODK.On Fri, Mar 21, 2014 at 9:04 AM, Rachel mail4...@gmail.com wrote:
doesn't work.Rachel
Groups
an
