Correct coordinates taken from ODK with Garmin
Hi to all,
I've tested the precision of ODK in collecting coordinates by comparing the coordinates taken by a Garmin, and I saw that ODK overestimated the position of few meters.
My question is: there is any approach to pair the professional GPS coordinates with ODK a more for reliable mapping?
Thanks a lot.
Others have definitely done what you ask.
Perhaps someone has written a bridging app that they can share to achieve
this?
And are you aware of the "accuracyThreshold" attribute?
See the snippet here:
··· On Wed, May 25, 2016 at 2:04 AM, wrote:
Hi to all,
Thanks a lot.
Hi Mitch, thanks for the answer.
I searched the forum to see if someone has done this with an external GPS, but I don't found any instruction about that.
I'm aware of "accuracyThreshold" attribute, but I created my form with Build tool, so I don't know if it would be possibile to put such attribute from there.
Thanks again.
··· > Others have definitely done what you ask. > > > Perhaps someone has written a bridging app that they can share to achieve this? > > > And are you aware of the "accuracyThreshold" attribute? > > > See the snippet here: > > > https://opendatakit.org/help/form-design/examples/#geolocation_prompts > > > > > > On Wed, May 25, 2016 at 2:04 AM, wrote: > Hi to all, > > I've tested the precision of ODK in collecting coordinates by comparing the coordinates taken by a Garmin, and I saw that ODK overestimated the position of few meters. > > > > My question is: there is any approach to pair the professional GPS coordinates with ODK a more for reliable mapping? > > > > Thanks a lot. > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google Groups "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com. > > For more options, visit https://groups.google.com/d/optout. > > > > > > -- > > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com
For ODK Build, you would need to edit the XML and add that attribute in
manually.
And there is also a setting in the device settings that selects whether to
also use wifi- or cell- based geodata when reporting coordinates.
This could also affect the accuracy of the returned coordinate.
from there.
Thanks again.
achieve this?
On Wed, May 25, 2016 at 2:04 AM, sust...@gmail.com wrote:
Hi to all,
Thanks a lot.
mitche...@gmail.com
For ODK Build, you would need to edit the XML and add that attribute in manually.
Ok, perfect, thanks for your clarification!
And there is also a setting in the device settings that selects whether to also use wifi- or cell- based geodata when reporting coordinates.
Yes thanks, I'm aware of that.
If the GPS you are using supports Bluetooth, you can pair your Android
device with that GPS
(https://play.google.com/store/apps/details?id=googoo.android.btgps&hl=en)
and ODK should be able to use those coordinates.
··· -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
Hi Yan, thanks a lot for the answer!
I will have a look to your solution, thanks again.
··· > If the GPS you are using supports Bluetooth, you can pair your Android > device with that GPS > (https://play.google.com/store/apps/details?id=googoo.android.btgps&hl=en) > and ODK should be able to use those coordinates. > > Yaw > -- > Need ODK consultants? Nafundi provides form design, server setup, > in-field training, and software development for ODK. Go to > https://nafundi.com to get started.
