I have a workflow in which I am names of teachers from 20 students using
repeat groups. We enter information about each student which includes who
their teacher is.
After looping through all 20 students, I want to find out how many students
each teacher has and pick out the top three teachers with the most students.
Any pointers on how I can achieve this?
Kind regards,
Sam
Sam,
There is no easy way of doing this.
You could put teachers in a select one, then used indexed-repeat() to
find the teacher values in each student. Then a lot of if() statements
that store a 1 if you match the known teacher.
Pseudo code would look like this:
student_1 = indexed-repeat(/data/students/teacher, /data/students, 1)
student_2 = indexed-repeat(/data/students/teacher, /data/students, 2)
teacher_a = sum(if(student_1 = teacher_a, 1, 0), if(student_2 =
teacher_a, 1, 0)...
teacher_b = sum(if(student_1 = teacher_b, 1, 0), if(student_2 =
teacher_b, 1, 0)...
Finding the top three is even messier. You could try using some
combination of max() or a ton of if() statements, but that sounds
painful. You could also list the results and maybe have the user pick
the top 3. Or just leave that as a server side calculation.
On Sat, Aug 23, 2014 at 4:59 AM, Ruralnet Kalundu ruralnetkalundu@gmail.com wrote:
their teacher is.
Kind regards,
Sam
