Customising forms
Hi all,
Is it possible to design custom skins/formatting for forms? So, for
example, displaying a logo at the top of a survey when it's being completed?
Calum
Hi all,
Just as a follow-up to this, are ODK forms HTML-based?
Calum
··· On Wednesday, December 21, 2016 at 3:18:53 PM UTC, Calum Handforth wrote: > > Hi all, > > Is it possible to design custom skins/formatting for forms? So, for > example, displaying a logo at the top of a survey when it's being completed? > > Thanks, > > Calum >
Hi Calum,
ODK forms are a subset of the far larger XForms 1.0 specification.
They contain a few additional features not found in the XForms
specification.
You can do some styling with Markdown.
http://xlsform.org/#styling
https://nafundi.com/blog/posts/customize-odk-forms-with-fonts-colors-sizes-and-links/
You can also add images/videos/audio to the form. For example, you can
have a select one about the types of birds where the choices are
videos of the various birds.
http://xlsform.org/#media
··· On Tue, Dec 27, 2016 at 12:23 PM, Calum Handforth wrote: > Hi all, > > Just as a follow-up to this, are ODK forms HTML-based? > > Calum > > > On Wednesday, December 21, 2016 at 3:18:53 PM UTC, Calum Handforth wrote: >> >> Hi all, >> >> Is it possible to design custom skins/formatting for forms? So, for >> example, displaying a logo at the top of a survey when it's being completed? >> >> Thanks, >> >> Calum > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups > "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
Hi Yaw,
This is really helpful, thanks!
If I wanted to change the menu bar, is this something that needs to be done
on the developer side? Are there any templates for surveys with
logos/custom headers at all?
Calum
··· On Wednesday, December 28, 2016 at 2:22:52 PM UTC, Yaw Anokwa wrote: > > Hi Calum, > > ODK forms are a subset of the far larger XForms 1.0 specification. > They contain a few additional features not found in the XForms > specification. > > You can do some styling with Markdown. > http://xlsform.org/#styling > > https://nafundi.com/blog/posts/customize-odk-forms-with-fonts-colors-sizes-and-links/ > > You can also add images/videos/audio to the form. For example, you can > have a select one about the types of birds where the choices are > videos of the various birds. > http://xlsform.org/#media > > Yaw > > On Tue, Dec 27, 2016 at 12:23 PM, Calum Handforth <calum.h...@gmail.com > wrote: > > Hi all, > > > > Just as a follow-up to this, are ODK forms HTML-based? > > > > Calum > > > > > > On Wednesday, December 21, 2016 at 3:18:53 PM UTC, Calum Handforth wrote: > >> > >> Hi all, > >> > >> Is it possible to design custom skins/formatting for forms? So, for > >> example, displaying a logo at the top of a survey when it's being > completed? > >> > >> Thanks, > >> > >> Calum > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google > Groups > > "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send > an > > email to opendatakit...@googlegroups.com . > > For more options, visit https://groups.google.com/d/optout. >
Calum,
You will need a developer to change the menu bar. You can find one at
https://opendatakit.org/help/help-for-hire.
··· On Wed, Dec 28, 2016 at 4:38 PM, Calum Handforth wrote: > Hi Yaw, > > This is really helpful, thanks! > > If I wanted to change the menu bar, is this something that needs to be done > on the developer side? Are there any templates for surveys with > logos/custom headers at all? > > Best, > > Calum > > On Wednesday, December 28, 2016 at 2:22:52 PM UTC, Yaw Anokwa wrote: >> >> Hi Calum, >> >> ODK forms are a subset of the far larger XForms 1.0 specification. >> They contain a few additional features not found in the XForms >> specification. >> >> You can do some styling with Markdown. >> http://xlsform.org/#styling >> >> https://nafundi.com/blog/posts/customize-odk-forms-with-fonts-colors-sizes-and-links/ >> >> You can also add images/videos/audio to the form. For example, you can >> have a select one about the types of birds where the choices are >> videos of the various birds. >> http://xlsform.org/#media >> >> Yaw >> >> On Tue, Dec 27, 2016 at 12:23 PM, Calum Handforth wrote: >> > Hi all, >> > >> > Just as a follow-up to this, are ODK forms HTML-based? >> > >> > Calum >> > >> > >> > On Wednesday, December 21, 2016 at 3:18:53 PM UTC, Calum Handforth wrote: >> >> >> >> Hi all, >> >> >> >> Is it possible to design custom skins/formatting for forms? So, for >> >> example, displaying a logo at the top of a survey when it's being >> >> completed? >> >> >> >> Thanks, >> >> >> >> Calum >> > >> > -- >> > -- >> > Post: opend...@googlegroups.com >> > Unsubscribe: opendatakit...@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> > --- >> > You received this message because you are subscribed to the Google >> > Groups >> > "ODK Community" group. >> > To unsubscribe from this group and stop receiving emails from it, send >> > an >> > email to opendatakit...@googlegroups.com. >> > For more options, visit https://groups.google.com/d/optout. > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups > "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
Hi Yaw,
I'm happy to look around in the code. Grateful if there are any resources
you could point me to, though! I'd imagine this question has come up
previously.
Calum
··· On Thursday, December 29, 2016 at 4:08:18 AM UTC, Yaw Anokwa wrote: > > Calum, > > You will need a developer to change the menu bar. You can find one at > https://opendatakit.org/help/help-for-hire. > > Yaw > > On Wed, Dec 28, 2016 at 4:38 PM, Calum Handforth <calum.h...@gmail.com > wrote: > > Hi Yaw, > > > > This is really helpful, thanks! > > > > If I wanted to change the menu bar, is this something that needs to be > done > > on the developer side? Are there any templates for surveys with > > logos/custom headers at all? > > > > Best, > > > > Calum > > > > On Wednesday, December 28, 2016 at 2:22:52 PM UTC, Yaw Anokwa wrote: > >> > >> Hi Calum, > >> > >> ODK forms are a subset of the far larger XForms 1.0 specification. > >> They contain a few additional features not found in the XForms > >> specification. > >> > >> You can do some styling with Markdown. > >> http://xlsform.org/#styling > >> > >> > https://nafundi.com/blog/posts/customize-odk-forms-with-fonts-colors-sizes-and-links/ > >> > >> You can also add images/videos/audio to the form. For example, you can > >> have a select one about the types of birds where the choices are > >> videos of the various birds. > >> http://xlsform.org/#media > >> > >> Yaw > >> > >> On Tue, Dec 27, 2016 at 12:23 PM, Calum Handforth wrote: > >> > Hi all, > >> > > >> > Just as a follow-up to this, are ODK forms HTML-based? > >> > > >> > Calum > >> > > >> > > >> > On Wednesday, December 21, 2016 at 3:18:53 PM UTC, Calum Handforth wrote: > >> >> > >> >> Hi all, > >> >> > >> >> Is it possible to design custom skins/formatting for forms? So, for > >> >> example, displaying a logo at the top of a survey when it's being > >> >> completed? > >> >> > >> >> Thanks, > >> >> > >> >> Calum > >> > > >> > -- > >> > -- > >> > Post: opend...@googlegroups.com > >> > Unsubscribe: opendatakit...@googlegroups.com > >> > Options: http://groups.google.com/group/opendatakit?hl=en > >> > > >> > --- > >> > You received this message because you are subscribed to the Google > >> > Groups > >> > "ODK Community" group. > >> > To unsubscribe from this group and stop receiving emails from it, > send > >> > an > >> > email to opendatakit...@googlegroups.com. > >> > For more options, visit https://groups.google.com/d/optout. > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google > Groups > > "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send > an > > email to opendatakit...@googlegroups.com . > > For more options, visit https://groups.google.com/d/optout. >
Hi Calum,
The code is pretty straightforward so that's your best bet!
··· _____________________________ From: Calum Handforth Sent: Friday, December 30, 2016 04:05 Subject: Re: [ODK Community] Re: Customising forms To: ODK Community
Hi Yaw,
I'm happy to look around in the code. Grateful if there are any resources you could point me to, though! I'd imagine this question has come up previously.
Calum
On Thursday, December 29, 2016 at 4:08:18 AM UTC, Yaw Anokwa wrote:Calum,
On Wed, Dec 28, 2016 at 4:38 PM, Calum Handforth calum.h...@gmail.com wrote:
Hi Yaw,
Calum
Hi Calum,
specification.
On Tue, Dec 27, 2016 at 12:23 PM, Calum Handforth calum.h...@gmail.com wrote:
Hi all,
Calum
Hi all,
completed?
Calum
Groups
an
