Is it possible, on an audio input prompt, to disable the "Choose Sound" button? We are finding that having that option available compromises data from other respondents using the same device by allowing this choice. Other workarounds would also be greatly appreciated!
Katrina
Hi Katrina,
You can't do this without editing the code in ODK Collect. If you want
this as an option, file a feature request at
https://code.google.com/p/opendatakit/issues/ or hire a developer from
http://opendatakit.org/help/help-for-hire to build it.
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Fri, Dec 13, 2013 at 2:51 PM, katrina.iiamshauser@gmail.com wrote:
Katrina--
Dear Yaw,
Thank you for your reply. It was exactly the information I needed.
Very best,
Katrina
