On Sat, Mar 24, 2012 at 08:49, Maurizio wrote:
> Hi, is there any resource available on how to customize ODK Collect?
> Thanks a lot in advance!
Hi, we would like to change the "labels" of the buttons at the entry page,
as well add our logo to it. Thanks!
On Saturday, March 24, 2012 4:54:20 PM UTC+1, Yaw Anokwa wrote:
> What exactly do you want to customize?
Note that most of these changes require you to maintain your own build
of ODK Collect, but the changes are minor enough that it shouldn't be
too much work.
Hope that helps,
If I got it right that means that I do not need to recompile the
application in the Android SDK right?
Cheers
Op zondag 25 maart 2012 20:53:55 UTC+2 schreef Yaw Anokwa het volgende:
> Maurizio,
> Changing button text and the like are straight forward, but you will
> need to be somewhat technical. Try getting
> http://developer.android.com/resources/tutorials/hello-world.html to
> work on a phone and if that goes fine, you'll be able to modify
> Collect.
> As Collect is a standard Android app, all you have to do is edit the
> various strings in
> http://code.google.com/p/opendatakit/source/browse/res/values/strings.xml?repo=collect
> The Collect icon is at
> http://code.google.com/p/opendatakit/source/browse/res/drawable-hdpi/notes.png?repo=collect
> Alternatively, you can use Collect's preferences to load a splash
> screen from the SD card.
> too much work.
> Hope that helps,
> Yaw
> page,
too much work.
Hope that helps,
page,
On Mon, Mar 26, 2012 at 10:27, Maurizio Bricola wrote:
> Hi Yaw, thanks you very much!
> If I got it right that means that I do not need to recompile the application
> Cheers
>> Maurizio,
>> Collect.
>> various strings in
>> http://code.google.com/p/opendatakit/source/browse/res/values/strings.xml?repo=collect.
>> http://code.google.com/p/opendatakit/source/browse/res/drawable-hdpi/notes.png?repo=collect.
>> too much work.
>> Hope that helps,
>> Yaw
>> > page,
Hi, thanks for the very prompt response. We were indeed thinking that would
be the case. I will sure let you know on the outcome! Cheers
Op maandag 26 maart 2012 19:31:18 UTC+2 schreef Yaw Anokwa het volgende:
> You will have to recompile the application.
> application
> > Cheers
> >> Maurizio,
> >> Collect.
> >> various strings in
> >> too much work.
> >> Hope that helps,
> >> Yaw
> >> > page,
> Collect?
I'm also interested in modifying ODK Collect. I have had difficulty
getting it to work from source though. Everything works fine when I
install Collect from the .apk or from the market; however, the app
crashes from nearly everything except starting up when I install from
source. I would greatly appreciate an explanation of the process I
need to follow to create an Eclipse project that installs identically
to the .apk. Thanks!
> > application
> > > Cheers
> > >> Maurizio,
> > >>http://developer.android.com/resources/tutorials/hello-world.htmlto
> > >> Collect.
> > >> various strings in
> >http://code.google.com/p/opendatakit/source/browse/res/values/strings...
> >http://code.google.com/p/opendatakit/source/browse/res/drawable-hdpi/...
> > >> too much work.
> > >> Hope that helps,
> > >> Yaw
> > >> > page,
> > Collect?
> > >> >> > Options:http://groups.google.com/group/opendatakit?hl=en
Please ask questions like this on (only) the opendatakit-developers@ list.
Beginning with the latest Android SDK, the Google Eclipse Plugin now pays
attention to the "Properties / Java Build Path / Order and Export"
settings. You need to ensure that the check boxes for the libraries shown
there are all checked except for the Google APIs and Android Dependencies.
Updated Eclipse project files will be checked into the tree as time permits.
> Mitch
>> > would
>> > > application
>> > > > Cheers
>> > > > volgende:
>> > > >> Maurizio,
>> > > >> will
>> > > >> Collect.
>> > > >> the
>> > > >> various strings in
>> > > >> build
>> > > >> be
>> > > >> too much work.
>> > > >> Hope that helps,
>> > > >> Yaw
>> > > >> > entry
>> > > >> > page,
>> > > Collect?
> Mitch Sundt
> Software Engineer
> University of Washington
> mitchellsundt@gmail.com
Thank you Mitch! That did the trick. And sorry for posting in the wrong
place. I think I found the right place now.
> permits.
> Mitch
>> would
>> > > application
>> > > > Cheers
>> volgende:
>> > > >> Maurizio,
>> will
>> > > >> Collect.
>> the
>> > > >> various strings in
>> build
>> be
>> > > >> too much work.
>> > > >> Hope that helps,
>> > > >> Yaw
>> entry
>> > > >> > page,
>> > > Collect?
> Mitch Sundt
> Software Engineer
permits.
