When I export data from aggregate to csv, it only exports the id not the
text value for all the select_multiple fields. How do I get the text.
Should I use another method for analysis
Anthony
Anthony
Correct. The data captured is the value code for the selection choice, not
the text label for that choice. Labels might be translated into many
different languages; it does not make sense to use the label in the output.
Given your original survey, especially if you use XLSForm, you should be
able to use the Excel functions VLOOKUP() or HLOOKUP() (I forget which...)
to map the value code back to a label of your choice.
That's actually one of the advantages of using XLSForm over Build -- you
have a sheet providing the mapping from the choice value codes -to- the
labels, so it is quite straightforward to define the mapping back to a
label if you need to.
Should I use another method for analysisAnthony
