Anybody could help me - I have uploaded the ODK XML form to the server,
than uploaded the filled form to the server which were uploaded
successfully. Now I want to export the data to CSV but its giving me
"Failure - will retry later" status. I have tried this several times from
last week but its giving me the same error.
Where am I making the mistake? Any solution to it? Else I have to enter all
the data forms in Android devices again by looking at the data in server.
Also you can pull your data out of Aggregate with ODK Briefcase and
generate a CSV from briefcase. Therefore your data should not be lost or
need to be re-entered.
Waylon
On Mon, Jul 30, 2012 at 9:18 AM, irum.jamshed < irum.jamshed@pakistan.theirc.org> wrote:
Anybody could help me – I have uploaded the ODK XML form to the server,
“Failure – will retry later” status. I have tried this several times from
last week but its giving me the same error.****
all the data forms in Android devices again by looking at the data in
server.****
Would be obliged.****
Irum Jamshed | Manager - Data Management International Rescue Committee
Irum.Jamshed@pakistan.theirc.org | +92 91 5703310 (Ext-105) | rescue.org
(1) Verify that you have not exceeded a usage quota by visiting the Billing
Status portion of your appengine dashboard, available through here https://appengine.google.com/ by clicking on your appengine instance.
(2) Verify that you are running the latest ODK Aggregate version. There was
an issue reported in v1.0.9 and v1.1 that could cause this failure. If you
are running those versions, upgrading to v1.2 can fix the issue.
If you don't remember what version you have deployed, if you go to the
AppEngine dashboard, click Logs, expand the options, and filter on the
string: *afterPropertiesSet *The first log entry will declare the Version
of ODK Aggregate -- e.g.,
org.opendatakit.common.security.Realm afterPropertiesSet: Version: v1.2.0
Production(3) If you are running the latest release, and you still have
this problem, then go back to the AppEngine dashboard, click on Logs, and
choose "Logs with Minimum Severity" and select "Error"
On Mon, Jul 30, 2012 at 3:45 PM, W. Brunette wrote:
What version of ODK Aggregate are you running?
server.****
Irum.Jamshed@pakistan.theirc.org | +92 91 5703310 (Ext-105) | rescue.org****
I get an "CSV file Failure - abandoned all retry attempts" exception everytime i try to export data to excel. I might have almost 500 data and i've installed the Aggregate(Tomcat,MySql)in my own server rather than google's to avoid what i am going through right now. The data were exported successfully until yesterday but today i've been trying this thing like forever but i get the same exception. I've been searching for a solution but nothing helping till now. Any idea what is going on?!?! Regards!!
wondering if this was resolved? I am getting the same error. I went through
all your suggestions, but none of those were the problem. I invited you as
a user if you would like to take a look. thanks!
On Monday, July 30, 2012 8:36:56 PM UTC-4, Mitch wrote:
> Things to try:
> Billing Status portion of your appengine dashboard, available through here
> was an issue reported in v1.0.9 and v1.1 that could cause this failure. If
> you are running those versions, upgrading to v1.2 can fix the issue.
> Be sure to follow any upgrade steps outlined in the release notes
> http://code.google.com/p/opendatakit/wiki/AggregateReleaseNotes The
> latest release is here:
> http://code.google.com/p/opendatakit/downloads/list
> Version of ODK Aggregate -- e.g.,
> There should be no errors. If there are, and it is unclear what needs to
> be done to fix the problem, please invite me as a developer to your
> AppEngine instance
> http://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
> Mitch
Upgrade to ODK Aggregate v1.3.4 -- there was an error in v1.3.3 that was
preventing this from working.
through all your suggestions, but none of those were the problem. I invited
you as a user if you would like to take a look. thanks!
Things to try:
Billing Status portion of your appengine dashboard, available through here https://appengine.google.com/ by clicking on your appengine instance.
org.opendatakit.common.**security.Realm afterPropertiesSet: Version:
v1.2.0 Production(3) If you are running the latest release, and you
still have this problem, then go back to the AppEngine dashboard, click on
Logs, and choose "Logs with Minimum Severity" and select "Error"
