I have a form where all the questions are in four different groups, the last of which is a repeated group. I had made a change to the form before filling out the surveys, and deleted the old blank form and replaced it with the new version. My surveys consists of visiting a site, which has multiple sample points, with each point containing multiple trees.
The first group of questions concerned the site. The next two groups were specific to the sample points, and the last (repeated) group was for trees. Initially, the last three groups had also been wrapped inside another repeat group, but I removed the repeat so that instead a new form would be filled out for each sample point. This change was to allow for geo points at each sample point to appear on the map within ODKcollect.
I had deleted the old form, and changed the google sheets url (for submission) to a new sheet. But, I didn't know about form versions, so I didn't change that. We then completed a days worth of surveys. When I tried to submit the surveys, I got the error message "not exactly one blank form matches this jr_form_id", which I now know had to do with me editing the old version of the form. So, I changed the version number of the form, and deleted the old blank form, and uploaded the blank form with the new version number onto my device. Now I was able to submit as per usual.
Except, when the files were submitted, only the data from the first group of questions showed up in the spreadsheet. The sheet made two more tabs- one for the repeat group which doesn't even exist on this version of the form, and the second for repeat group which does. Both tabs are completely blank.
When I look at the filled forms on my device, I can also only see the first group. What's weird, is that I can correctly see the geopoints from the sent forms on the map on the device, even though the geopoint was in one of the question groups which has disappeared.
Is there anyway to get this data back? What happened here?
ODKcollect on a android tablet with google drive as the server
I've tried resending the forms, and re-uploading the blank form, with no luck.
