I am an Agricultural Researcher. I have data available after 3 years of
research from various aspects. I am going to using ODK further in my
research. The query I have is , with all the available data gathered and
refined properly in spreadsheets, will I be able to do data manipulation
from different sheets from a spreadsheet using ODK. If, so, can you tell me
which function to use.
I'm not sure that I understand what you want to do with your existing data.
But if you want to reference that data in new ODK forms (as multiple-choice
options, as information notes, as repeat-group counts, etc.), then you
currently have two choices: (1) wait for ODK 2.0, which will have this kind
of functionality, or (2) use SurveyCTO, which has support for pre-loading
data today (at www.surveycto.com). Also, Nafundi has recently added ODK
support for loading multiple-choice options from .csv files, so that might
work for you in the latest ODK Collect. I'm not sure if that's become
documented and supported yet, but Yaw may respond with some suggestions for
how you might use that.
Chris
Let me break it down to earth. What are the data manipulation techniques
(Regression, Correlation, etc) available in ODK? I got familiar with
collect within a couple of days but I am not sure what kind of analysis I
can do with the ODK.
Shriram
On Tue, Sep 17, 2013 at 5:08 PM, Christopher Robert wrote:
Hi Shriram,
data. But if you want to reference that data in new ODK forms (as
multiple-choice options, as information notes, as repeat-group counts,
etc.), then you currently have two choices: (1) wait for ODK 2.0, which
will have this kind of functionality, or (2) use SurveyCTO, which has
support for pre-loading data today (at www.surveycto.com). Also, Nafundi
has recently added ODK support for loading multiple-choice options from
.csv files, so that might work for you in the latest ODK Collect. I'm not
sure if that's become documented and supported yet, but Yaw may respond
with some suggestions for how you might use that.
ODK will let you export data to Google Fusion Tables and you can set up
some basic data-analysis and/or -visualization there. But the bottom line
is that ODK is for the actual data-collection -- not for data-analysis or
-manipulation. ODK hands off the data, then it's up to you what to do with
it. In my projects, we use Stata. You can use whatever tools or techniques
you wish.
A standard workflow is: use ODK Briefcase to export data to .csv files,
then take it from there.
Chris
On Wed, Sep 18, 2013 at 5:08 AM, Shriram Manogaran wrote:
Hi Chris,
Groups "ODK Community" group.
On Wed, Sep 18, 2013 at 4:26 PM, Christopher Robert wrote:
Hi Shiram,
you wish.
Nafundi has recently added ODK support for loading multiple-choice options
from .csv files, so that might work for you in the latest ODK Collect. I'm
not sure if that's become documented and supported yet, but Yaw may respond
