Dear all,
We have an Hybrid Android application which uses ODK Collect to do
Demographic Surveillance surveys while the Android app does some custom
functions including pre-filling ODK Forms with data stored on the device
(User Data, Household Data, etc). For reasons I am yet to understand, ODK
stores Finalized Forms after a household visit, and the data can be seen
when one goes to Edit Saved Form. However, after a few forms have been
filled (no specific number) forms erratically start to lose data, and going
into Edit Saved Forms all you see is the form fields but the form is now
blank. This is quite erratic, in the sense that one does not know when
exactly it deletes data (some fieldworkers claim after 5 visits, others
claim after seven visits, etc) but also erratic in the sense that the same
form, e.g a pregnancy-outcome form during the course of an interviewers day
will produce some instances where there is no data deletion and other
instances where data has been deleted.
Could anyone guide me as to where would be the first place to look, in
terms of trying to debug this?
Appreciate any help,
Tumaini
Hi Tumaini,
You have to be careful about relevance when you restore or save a
form. If you open a form, change relevance, and save that form,
JavaROSA will discard any data that isn't relevant. I think the engine
will also throw away empty nodes. I'd start there...
Need ODK services? Go to http://nafundi.com for form design, data
cleaning, custom reporting, and software development for ODK.
On Fri, Aug 16, 2013 at 8:23 AM, Tumaini Kilimba tkilimba@ihi.or.tz wrote:
Dear all,
Could anyone guide me as to where would be the first place to look, in terms
Tumaini
"ODK Developers" group.
Hello Yaw, thanks for the response. Could you elaborate a little more
please, when you say "open a form and change its relevance" do you mean
opening the forms xml file in an editor and modifying it?
Also, wrt throwing empty nodes, you mean throwing nodes with no data?
Because in our case, all the data is lost from a saved form.
Appreciate the help,
Tumaini
On 17 Aug 2013 01:58, "Yaw Anokwa" wrote:
Hi Tumaini,
Dear all,
going
same
day
terms
Tumaini
Tumaini,
I mean editing a saved form on the phone and re-saving it. Let's say
you have a saved form where gender is female and you save relevant
questions (e.g., about pregnancy). Then you edit that saved form in
Collect, switch gender to male, and save the form. All the
non-relevant questions (e.g., about pregnancy) will be discarded.
Empty nodes are nodes like or where you
don't have any data stored inside the node, but the node is present.
If you are generating forms via code, you might think that those nodes
get read by JavaROSA, but that's not necessarily true.
If you are losing all the data in the form, then something else is
probably going on. I'd look at the SQLite DBs and see if there is a
mismatch between the metadata and the XML files. I'd also check to
make sure nothing weird is going on with your SD card (especially if
the problems happen only on some phones).
Tumaini
On 17 Aug 2013 01:58, "Yaw Anokwa" yanokwa@nafundi.com wrote:
Hi Tumaini,
Dear all,
ODK
going
same
day
terms
Tumaini
Groups
an
Thanks againYaw,
whenu say "see if theres a mismatch between the metadata and xml", what do
you mean? Also, within the same device you can have 5 instances of
"pregnancy_outcome" form, yet only two will have no data, and the other
three would be fine. Would a mismatch affect ALL instances of a form, or
could such random selectiveness occur?
Tumaini
Tumaini,
Tumaini
Hi Tumaini,
Dear all,
custom
device
ODK
seen
been
going
now
when
others
same
interviewers
day
in
terms
Tumaini
Groups
send
an
Groups
an
Groups
an
On 17 Aug 2013 15:51, "Yaw Anokwa" wrote:
If you have a DB entry but no XML or vice versa, then that's a place
to start. Or if the timestamps of when the DB said you updated a file
and the file itself differ by a lot, then that's a place to start. My
intuition is that if you have some sort of DB or filesystem issue, it
could be random. Anyway, all this is speculation. Best thing to do is
start from the code you changed, look through the /odk folder of the
good devices and the bad, add logging, test, etc.
On Sat, Aug 17, 2013 at 6:02 AM, Tumaini Kilimba wrote:
> Thanks againYaw,
> Thanks,
> Tumaini
>> Tumaini,
>> Yaw
>> > Tumaini
>> >> Hi Tumaini,
>> >> Yaw
>> >> > Dear all,
>> >> > custom
>> >> > device
>> >> > ODK
>> >> > seen
>> >> > been
>> >> > going
>> >> > now
>> >> > when
>> >> > others
>> >> > same
>> >> > interviewers
>> >> > day
>> >> > in
>> >> > terms
>> >> > Tumaini
>> >> > You received this message because you are subscribed to the Google
>> >> > Groups
>> >> > send
>> >> > an
>> >> Groups
>> >> To unsubscribe from this group and stop receiving emails from it, send
>> >> an
>> > Groups
>> > an
