i have made a tool there are some note type in the tool. when i downloaded dataset note variable is also there. can i make it that it cannot come in dataset. is this possible.
Hi @Rakesh_Ranjan,
Unfortunately no, you can do that manually after downloading the dataset.
Hi @Rakesh_Ranjan,
You can do data management, where you can make different syntax file where you can write code for remove unnecessary variable and then make a clean dataset.
@iamnarendrasingh
