What is the problem?
Hi all,
I was wondering if there is a way to set a default offline map layer (i can see there is a way to set default coordinates which is great, but trying to avoid users having to manually select the layer). Many thanks for your help!
Spike
Hi @spike
If you have online layers you can select them in General Settings -> User interface -> Mapping
Hi all,
I have the exact same question as Spike : is there a way to set a default offline map layer ?
I try to make my form as easy as possible because my users aren't familiar with tablet computers.
Thank you for your help.
Margoulin
