Using Collect, I am trying to get a default value into an instance file
from XLSForm without the user seeing the value. Put another way, I want to
be able to specify a value via XLSForm that appears in every instance file.
A natural way to try this would be to specify a default value and indicate
that the question isn't relevant (thus hiding it from the user), but of
course this doesn't work because if it isn't relevant it doesn't appear in
the instance file.
Is there another way to do this? I'd like to use the string for processing
down my pipeline. It doesn't need to be able to reference other form data
or anything tricky, it just needs to appear in the instance file.
Hi Sam,
Use a question of type calculate with the magic string in default.
What you put as the calculation is up to you.
type:calculate
label: my_label
default: my_processing_string
calculation: today()
Relatedly, you can add attributes to various nodes by using the
instance::my_attribute, bind::my_attribute, and body::my_attribute.
On Sat, Aug 20, 2016 at 3:55 PM, Sam Sudar sudar.sam@gmail.com wrote:
Using Collect, I am trying to get a default value into an instance file from
XLSForm without the user seeing the value. Put another way, I want to be
the instance file.
down my pipeline. It doesn't need to be able to reference other form data or
