Hi?
Is it possible to pull data from say; a database using the =Index or Match
or Vlookup function?
I am authoring a site supervision form to be used in ODK Collect. The
supervisors should be able to see a "read-only" field that contains the
baseline number, before they record the current indicator statistic
(number).
Thank you in advance for your assistance.
Hi Louis,
Use preloading. https://opendatakit.org/help/form-design/data-preloading/
Need ODK consultants? https://nafundi.com provides form design, server
setup, in-field training, and software development for ODK.
On Sun, Oct 11, 2015 at 10:16 PM, Louis Omoya louisomoya@gmail.com wrote:
Hi?
(number).
Thank you. I will try this out.
On Mon, Oct 12, 2015 at 6:11 AM, Yaw Anokwa wrote:
Hi Louis,
Hi?
Match
(number).
