- How can I delete data and forms from collector;s mobile. either remotely
or giving them button on screen.*
Do not want to tell them in folders and delete from there.
techbyte101
techbyte101
One solution you could use would be to synchronize your folders using
DropSync/DropBox. Maintain your forms on your desktop, when you delete them
from the desktop folder, they will be deleted from the phones when they
perform a sync.
☞§※☼:airplane:
~Neil
remotely or giving them button on screen.*Do not want to tell them in folders and delete from there.
techbyte101--
"ODK Developers" group.
Neil,
Have you had good luck using Dropbox? I heard bad things could happen:
https://groups.google.com/d/msg/opendatakit/0yTr_C-ybDc/DrWsI0GpCskJ.
perform a sync.☞§※☼:airplane:
or giving them button on screen.Do not want to tell them in folders and delete from there.
techbyte101--
Well, that does give me some worry, but I haven't had that problem. We did
some dropbox testing in Congo, and I have been using it for a while to sync
all of my forms and data, I never cable in anymore. I've been doing this to
test for deployment, but we haven't yet used in if a full scale project.
Would you recomend avoiding dropbox?
☞§※☼:airplane:
~Neil
Neil,
https://groups.google.com/d/msg/opendatakit/0yTr_C-ybDc/DrWsI0GpCskJ.Yaw
Need ODK help? Go to http://nafundi.com for custom development, form
design, implementation support, and user training for ODK.On Tue, Feb 26, 2013 at 6:27 AM, Neil Hendrick mojotexas@gmail.com wrote:
them
remotely
techbyte101--
Groups
an
Neil,
I don't know if I'd avoid it, but I'd be cautious about auto-syncing
or using both apps at precisely the same time.
Would you recomend avoiding dropbox?☞§※☼:airplane:
~NeilOn Tue, Feb 26, 2013 at 10:34 AM, Yaw Anokwa yanokwa@nafundi.com wrote:
Neil,
them
remotely
techbyte101--
Groups
an
Groups
an
