# Difference between Suitcase and Briefcase
**URL:** <https://forum.getodk.org/t/difference-between-suitcase-and-briefcase/13206>\
**Category:** Support\
**Created:** [May 22, 2018, 7:42pm UTC](https://forum.getodk.org/t/difference-between-suitcase-and-briefcase/13206 "2018-05-22T19:42:27Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Saad](https://getodk.b-cdn.net/user_avatar/forum.getodk.org/saad/32/4537_2.png) [@Saad](https://forum.getodk.org/u/Saad)\
**Post date:** [May 22, 2018, 7:42pm UTC](https://forum.getodk.org/t/difference-between-suitcase-and-briefcase/13206/1 "2018-05-22T19:42:27Z")
</div>
Whats the difference between ODK briefcase and Suitcase?
Saad
**Author:** ![abdoul](https://getodk.b-cdn.net/user_avatar/forum.getodk.org/abdoul/32/16916_2.png) [@abdoul](https://forum.getodk.org/u/abdoul)\
**Post date:** [May 22, 2018, 8:35pm UTC](https://forum.getodk.org/t/difference-between-suitcase-and-briefcase/13206/2 "2018-05-22T20:35:42Z")
</div>
Hello deat you can fine explanation of [Briefcase](https://docs.opendatakit.org/briefcase-intro/) and [Suitecase](https://docs.opendatakit.org/odk2/suitcase-intro/).
I’ve never use suitecase but for briefcase you can use it to pull date from you form and more.
See links hoe they’ll help you.
